Casio Pro fx-1 card reader programmable
07-11-2019, 12:17 AM
Hello all,
Taking some time off to play. Restored, that is dis-assembled my working FX-1 to repair some bouncy keys. Of course this means a full PCA cleaning as well as shell. All functions work perfectly but the card reader status is unknown. I have some new cards arriving from England soon. In the mean time I have been writing some programs for the calculator. I do have an fx-201p which I have restored earlier this year so messing with the coding (semi FORTRAN) is fun. In any case, three things: 1) does the card reader record data registers along with program coded? It would be helpful, especially with programs requiring many constants. That would save loading constants beforehand into the requisite registers. 2) does anyone have a calculator manual for the fx-1 in PDF format that they are willing to share. I have the fx-201p manual but it does not discuss the card reader do’s and dont’s. 3) Does anyone have the program manual in PDF format that they are willing to share? Cheers, Geoff Will probably do a YouTube video on the fx-1 as well as my HP 29LP IR. |
07-11-2019, 03:01 AM
(This post was last modified: 07-11-2019 03:02 AM by toml_12953.)
RE: Casio Pro fx-1 card reader programmable
(07-11-2019 12:17 AM)Geoff Quickfall Wrote: Hello all, Here are the card reader instructions. Make sure you follow the instructions in the Special Note! https://www.dropbox.com/s/e3jgvaq07e0nyn...s.pdf?dl=1 Tom L Cui bono? |
07-11-2019, 04:26 AM
Thanks Tom!
07-12-2019, 04:05 AM
I guess the AC and MAC on the special note before recording answers the: “ is data in the registers also recorded” question!
Cards arrived today and the calc reads and records and without the gummy wheel problem! Geoff |
07-13-2019, 04:21 AM
(This post was last modified: 07-13-2019 04:22 AM by Geoff Quickfall.)
Here is the calc working and some of Andrews Menadues’ cards which I labelled with transparent label stock. Sticky on ones side and translucent. Very thin, thinner then paper label material.
For cards with programs and labels made up so far: And the cards: |
07-14-2019, 05:18 PM
(This post was last modified: 07-14-2019 05:20 PM by toml_12953.)
(07-12-2019 04:05 AM)Geoff Quickfall Wrote: I guess the AC and MAC on the special note before recording answers the: “ is data in the registers also recorded” question! Right! No wheels so no gummy wheels! Make sure you don't have gummy hands, though. Those cards are so cool! Tom L Cui bono? |
07-15-2019, 09:13 PM
(07-13-2019 04:21 AM)Geoff Quickfall Wrote: Here is the calc working and some of Andrews Menadues’ cards which I labelled with transparent label stock. Sticky on ones side and translucent. Very thin, thinner then paper label material. Your cards look wonderful. What kind of transparent labels did you use? |
07-16-2019, 01:26 AM
Standby, i am away from home but will post the Avery product number when i get back Thursday.
Cheers Email me and i can send you the photoshop file correctly sized. Will be reproducing the back side next. |
04-16-2020, 01:26 PM
RE: Casio Pro fx-1 card reader programmable | |||
04-16-2020, 06:13 PM
(This post was last modified: 04-18-2020 03:22 AM by Geoff Quickfall.)
These are not elegant examples of coding!!!! I wanted to see how the calcs performed so I quickly wrote these routines in a language I was not familiar with. Yes have programmed in FORTRAN but not like this!
Hope they give you ideas. The moon phase is not my program and I am trying to remember and/or find the link. I will update the citation when i find it. Cheers, Geoff P.S. they are beautiful machines to say the least. Great circle distance and track Intermediate latitude Cold weather (temp<10’C application): Fuel in tank at prior to departure: fuel in tank is a check that the fuel IS in your tank ;-) A = TOTAL FUEL AFTER REFUELLING IN KILOGRAMS - B = ARRIVAL FUEL IN KILOGRAMS C = FUEL REQUIRED TO BE LOADED. D = TENDER UPLIFT (FUEL LOADED IN LITRES) E = FWCF (SPECIFIC GRAVITY OF ‘A’ OR ‘A1’ KEROSENE (SG) F = TENDER UPLIFT IN KILOGRAMS G = DIFFERENCE IN KILOGRAMS DIFFERENCE BETWEEN THE THE ‘C’ AND ‘F’ ON THE 787 AND 777 MUST BE < 5%. C = A - B F = D X E G = C - F % = (A - G) / A * 100. (Left this bit off the code as I am more interested in the difference in kilograms, especially if under required or making the aircraft over max taxi, ramp or takeoff weight. Moon Phase: ETOPS legalities Conversion routines; imperial to metric and back Unfortunately these models will convert sexidecimal to decimal but not back so here is a routine that does what the HR->HMS functions do on the HP: The routine is too long to include in the Intermediate latitude program which can convert your HMS latitude and longitude to decimal lat and Lon. But cannot convert it back to HMS. Useful links: Description and some coding YouTube of the cards manufacturer The producer of the new replacement cards and a member here: Hpmuseum link about cards |
04-16-2020, 08:50 PM
(04-16-2020 06:13 PM)Geoff Quickfall Wrote: a language I was not familiar with ... FORTRAN but not like this Thank you for the very detailed answer, as I can see the language, I must to check a manual and/or an emulator if available somewhere... Really strange language. "they are beautiful machines to say the least" Yes, but I do not know the scale, how these calcs are "big" eg. near by a HP-1xC? Viktor Toth wrote on his website, the "one pound of calculator". Csaba |
04-16-2020, 09:58 PM
Definitely coat pocket not shirt pocket!
Here is a shot of an HP67 case and the case I am using for the Pro fx-1: Size comparison between HP 67 and the Pro fx-1 Size comparison between HP 67 and the fx-202p |
04-18-2020, 02:35 AM
(This post was last modified: 04-18-2020 02:36 AM by toml_12953.)
(07-13-2019 04:21 AM)Geoff Quickfall Wrote: Here is the calc working and some of Andrews Menadues’ cards which I labelled with transparent label stock. Sticky on ones side and translucent. Very thin, thinner then paper label material. Do you have a file containing a picture of the card face you could share? I just bought 20 blank cards but they have no graphics on them. Also, what's the Avery number of the label template? Thanks for your time! Tom L Cui bono? |
