Hp prime Copy and pasting problems - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Hp prime Copy and pasting problems (/thread-4427.html) Pages: 1 2 |
RE: Hp prime Copy and pasting problems - Thomas_Sch - 08-07-2015 03:15 PM (08-07-2015 02:53 PM)Tim Wessman Wrote: Yes, there appears to be another issue related to digit grouping. Hello Tim, many thanks for the quick and detailed response! I did not mean to annoy you, the issue should remain visible only. There are more sensible ways to report bugs? RE: Hp prime Copy and pasting problems - Arno K - 08-07-2015 03:29 PM (08-07-2015 02:53 PM)Tim Wessman Wrote: Yes, there appears to be another issue related to digit grouping.Hello Tim, with my posting above I did not directly address you, but thank you for your answer, better late than never. I have put that program aside for the moment and wait for future releases, hoping for a fix. For that reason I asked for a sticky thread, therein links to posts describing bugs could be posted and erased after they are fixed. I don't like that tricider-site by eried. Good to know that there are some persons dealing with bugs. Thanks Arno RE: Hp prime Copy and pasting problems - Tim Wessman - 08-07-2015 03:38 PM Thanks. Note that I wasn't complaining at your or anyone directly - i was just trying to explain what might be going on and some of the limitations I work under. Always, the absolute best way to get a response it to call in and complain at support. Barring that, a public post is a good way to get an issue addressed as we do actively monitor. Hopefully, at some point in the future a public bug tracker can be hosted. I'd like that personally, but don't know if there will still be policies against that sort of thing. RE: Hp prime Copy and pasting problems - Gerald H - 08-07-2015 03:45 PM Serendipitous that Arno K's thread http://www.hpmuseum.org/forum/thread-4181.html?highlight=bug%3F+in receives an answer in this thread while his own thread is left dangling. RE: Hp prime Copy and pasting problems - Thomas_Sch - 08-07-2015 05:20 PM (08-07-2015 03:45 PM)Gerald H Wrote: Serendipitous that Arno K's threadYou could set a link ? RE: Hp prime Copy and pasting problems - Gerald H - 08-07-2015 06:21 PM Yes, I could...Or you could...Or someone actually involved in answering Arno K's problem could... My attention for the Prime is small & surely my meddling isn't up to the Herculean task of straightening it's problems, so for now I'll fade away... I'd be more pleased to get a solution to this http://www.hpmuseum.org/forum/thread-4458.html as long as we're crossing threads... RE: Hp prime Copy and pasting problems - John Colvin - 08-07-2015 06:36 PM (08-07-2015 05:21 AM)Gerald H Wrote: So, pr011235, you have announced a bug & no one says thank you.I replicated the problem/bug using four-digit numbers. As the subsequent posts have stated, removing digit groupings from Settings allows copy and paste of four and larger digit numbers to the Stats App. Should work with digit grouping though. RE: Hp prime Copy and pasting problems - Gerald H - 08-08-2015 05:00 AM Thanks for going to the trouble, John, but given Thomas' precise analysis the matter is now concluded (as far as the Forum is concerned)- |
