Help with Base / Base conversion - Printable Version +- HP Forums (https://www.hpmuseum.org/forum) +-- Forum: HP Calculators (and very old HP Computers) (/forum-3.html) +--- Forum: HP Prime (/forum-5.html) +--- Thread: Help with Base / Base conversion (/thread-1567.html) |
Help with Base / Base conversion - Angus - 06-07-2014 10:04 PM hi, I would like to ask for help with the base things. I am not sure if there were changes in the latest patch or if I just did not notice what puzzles me right now. Here we go: I am in home mode, rpn entry. The system can be set to an integer base (say hex) so #123 is the short form for #123h. As in the 48 series, right? Then in the prie we got the dialog based conversion window I don't understand atm. Here are some questions: The Stack is empty, no entry on the entry line. I press shift+'-', so # is added to entry. Pressing shift+'-' again opens zu dialog. That seems to be wanted in my eyes. I can now enter any number wich is interpreted as Sytem base format. Q: To have my entry in a different format I need to change the global integer setting? It can't be done in the dialog? That would be helpful considering we have a complex entry mask. The Stack is empty, no entry on the entry line. I press shift+'-', so # is added to entry. Now I clear the entry with on. Pressing shift+'-' again open the dialog althogh nothing is in the entry line and I would expect to start again with '#'. Thinking of a state machine like handling. The Stack is empty. I enter 123. no return yet. Pressing shift+'-' opens the dialog. I would have expected to see 123 as an initialized value, but nothing is there. I enter 4. And finish the dialog with ok what results in 123#4h in th entry line. That seems weird to me. I would have expected to initialize the dialog with 123. The Stack is emtpy. I enter #55. ENTER. So that the value is pushed on the stack. shift+'-' then picks the integer for initializatino on the dialog. That has something to do with differentiating the entry line and stack 0. Treating the entry Line as Stack 0 or x-reg if you want would be a great improvement and a first step into improved rpn mode don't you think? I did not play with cas - do you have information if base manipulation is integrated in the cas meanwhile? Thank you |
