11-16-2017, 09:18 PM
11-16-2017, 09:24 PM
FP_RAT() in capital letters indicating a home function could be an acceptable choice, second best, when RATAPPROX is too long, I have the impression, that I very often select functions from the menus, so length doesn't matter, and when I write a program I prefer short names, so 3 letters can be hit by an arbitrary name given to some subroutine.
Arno
Arno
11-16-2017, 11:18 PM
(11-16-2017 05:50 PM)salvomic Wrote: [ -> ]• rational_form
(11-16-2017 06:45 PM)DrD Wrote: [ -> ]Since it involves changing a floating point to rational number....
Sorry,
but sqrt(2) is not rational, but is irratonal no ?
So every name with "rational" only shoud be avoided.
maybe normalize(), but I don't like it too much myself
or toALG() ?
11-17-2017, 12:02 AM
(11-16-2017 11:18 PM)primer Wrote: [ -> ]but sqrt(2) is not rational, but is irratonal no ?→Qπ attempts to approximate expr into one of the following forms using digits of precision: p/q, (a/b)*√(p/q), (p/q)*π, ln(p/q) or e^(p/q)...
Rational under square root. This command is related to rational.
11-17-2017, 12:06 AM
What would a novice think QPI(4.5) means if they saw it in the source code and hadn't previously read this thread?
PPL supports implied multiplication, yes?
So QPI(4.5) can be parsed as QPI*(bracketed-expression), yes?
I haven't looked it up yet, but I might guess its a constant equal to QuarterPi, or Pi/4, multiplied by 4.5. (For comparison: many algorithms use the constant TwoPi = 2*Pi to avoid the cost of a multiply).
So let's forget the reference to Pi, at least, which it has nothing to do with.
To be consistent with other HP Prime conversion names, such as mat2list, something like fp2exact seems reasonable for now. However, the "fp" part bothers me.
Why?
What would you expect fp2exact(#2) to do?
Or fp2exact(2.1+2.2i)
The intuitive result of giving it a complex number seems obvious enough:
21/10 + (22/10)i or something (I haven't checked exactly what the output should be, but I guess it should be complex)
So do we need
Complex2exact
String2exact etc.?
Perhaps just
Convert2exact(anything), or ToEXACT for brevity,
But then for consistency mat2list ought to be
Convert2list or Tolist etc.
Why?
So do we need
Complex2exact
String2exact etc.?
Perhaps just
11-17-2017, 12:09 AM
(11-17-2017 12:02 AM)Voldemar Wrote: [ -> ]Rational under square root. This command is related to rational.Yes "related", but result isn't rational.
And I found weird to call that function something like to_rat() or fp_rat() which doesnt return a rational result.
11-17-2017, 12:22 AM
(11-16-2017 07:39 PM)DrD Wrote: [ -> ]Since any number can be divided by 1, they are all rational numbers.
Am I missing something or is this is a suggestion to redefine "rational number" to mean "any number"?
Suggesting that square roots, multiples of pi etc should be called "rational numbers" in general seems pretty silly to me. And baking it into function name extremely misleading.
EDIT: oops this was picked up already...
11-17-2017, 12:28 AM
(11-17-2017 12:09 AM)primer Wrote: [ -> ]And I found weird to call that function something like to_rat() or fp_rat() which doesnt return a rational result.You are right. Let’s try to figure out another name.
11-17-2017, 12:39 AM
How about «show rational part»?
SRP
SRP
11-17-2017, 12:52 AM
I don't know what is meaning of QPI output. Is it only visualition or it is something which can be stored into variable (or variables as there are p and q) for example?
If it is the former, then it is similar to [a b/c] key and it could be on almost empty menu bar (where is nothing more than Sto >) as f(p/q) or something.
I'm sorry if I'm talking nonsense.
11-17-2017, 02:31 AM
RATCOMP
Rational Composition -- all the results are essentially the composition of ->Q(X) with one of the following functions: 1(X) (identity), SQRT(X), EXP(X), LN(X), or PI(X) (multiplication by PI).
For a shorter name:
QFORM
Q for rational, and FORM because the program converts the numerical value into some form involving a rational value. Or perhaps RATFORM
If not QPI, then I would lean in favor of RATCOMP
For a shorter name:
QFORM
11-17-2017, 06:25 AM
Assuming that it finds the nearest approximation, perhaps something like QNEARF, or possibly just NEAR?
11-17-2017, 10:41 AM
if it's going to be built-in some day, it would be logical to assign it to the a b/c button in certain contexts. Currently, this is the approx and when you hit it again, it does the opposite = exact.
So, if you do exact(0.428571428571) it gives you 3/7 currently.
Hey, I just realized that QPI seems to be a more advanced exact() command.
Maybe we should just replace exact with the functionality in the QPI command. I added the qpif command suggested in Han's original post....wondering if maybe that's the version that gets called in CAS mode and the regular QPI gets called in Home mode.
11-17-2017, 01:33 PM
I like QPI (for consistency with the HP 48/49/50G family) or RAT (rationalize).
11-17-2017, 01:35 PM
(11-17-2017 01:33 PM)Eddie W. Shore Wrote: [ -> ]I like QPI or RAT (rationalize).
QPI (as the Han's version) is ok, and also RAT, yeah. However, if the problem is only the -> (in CAS I think) also Qπ could be ok...
11-17-2017, 03:21 PM
The name must encompass a meaningful name for some functions that it performs
QPIRLNe: convert decimal to ℚ(p/q) or p/q*PI or SQRoot(p/q) or LN(p/q) or e^(p/q)
qpi_approx();
qpi_asqrtb();
qpi_out();
qpi_outsqrt();
qpi_real();
qpi_complex();
qpi_list();
qpi_root();
qpi_pi();
qpi_ln();
qpi_exp();
qpi_symb();
By tradition is QPI (hp48/50) but it does not report everything it can do, I propose QPIRLNe name from Q Quotient (fraction p/q) + or PI+ or ROOT+ or LN+ or e
Who else agrees with QPIRLNe?
qpi_approx();
qpi_asqrtb();
qpi_out();
qpi_outsqrt();
qpi_real();
qpi_complex();
qpi_list();
qpi_root();
qpi_pi();
qpi_ln();
qpi_exp();
qpi_symb();
PHP Code:
// QPI by Han Duong
// ported from QPI 4.3a for the HP48G/GX by Mika Heiskanen & Andre Schoorl
export qpiEXPLN:=100; // max denom for exp(p/q) or ln(p/q)
export qpiMAXINT:=2^20; // largest n allowed for sqrt(n)=a*sqrt(b)
export qpiDIGITS:=10; // controls accuracy (best results at 9 or 10)
qpi_approx();
qpi_asqrtb();
qpi_out();
qpi_outsqrt();
qpi_real();
qpi_complex();
qpi_list();
qpi_root();
qpi_pi();
qpi_ln();
qpi_exp();
//qpi_symb();
EXPORT QPI(r)
case
if TYPE(r)==0 then qpi_real(r); end;
if TYPE(r)==1 then RETURN(r); end;
if TYPE(r)==3 then qpi_complex(r); end;
if TYPE(r)==6 then qpi_list(r); end;
if TYPE(r)==8 then QPI(approx(r)); end;
DEFAULT msgbox("Object type: " + TYPE(r) + " not supported!");
end;
qpi_real(r)
local frac;
if r then
frac:=qpi_approx(r);
if frac(2)<100 then
qpi_out(frac);
else
qpi_root(r,frac);
end;
else
RETURN(0);
end;
qpi_complex(c)
local rpart, ipart;
rpart:=STRING(qpi_real(RE(c)));
ipart:=STRING(qpi_real(abs(IM(c))));
if IM(c)>0 then
expr("'" + rpart + "+" + ipart + "*'");
else
expr("'" + rpart + "-" + ipart + "*'");
end;
qpi_list(l)
local i,n;
n:=SIZE(l);
for i from 1 to n do
l(i):=QPI(l(i));
end;
RETURN(l);
qpi_root(r,frac)
local frac1;
if r^2<500001 then
frac1:=qpi_approx(r^2);
if r<0 then frac1(1):=-frac1(1); end;
frac1(3):=1;
if (frac1(2)<1000) AND (frac1(2)<=frac(2)) then
if frac1(2)<10 then
qpi_out(frac1);
else
qpi_pi(r,frac1);
end;
else // sqrt denom not smaller
qpi_pi(r,frac);
end;
else // r^2>500000
qpi_pi(r,frac);
end; // end_if r^2<500000
qpi_pi(r,frac)
local frac1;
if abs(r/pi)<101 then
frac1:=qpi_approx(r/pi);
frac1(3):=2;
if frac1(2)<10 then
qpi_out(frac1);
else
qpi_ln(r,frac1);
end;
else // (r/pi) denom not smaller
qpi_ln(r,frac);
end;
else // abs(r/pi)>100
qpi_ln(r,frac);
end; // end_if abs(r/pi)<101
qpi_ln(r,frac)
local frac1,tmp;
tmp:=e^(r);
if tmp<1001 then
// check for LN(0)
if tmp then
frac1:=qpi_approx(tmp);
else
frac1:=qpi_approx(MINREAL);
end;
frac1(3):=3;
if (frac1(1)*frac1(2)==1) OR (frac1(2)>qpiEXPLN) then
qpi_exp(r,frac);
else
if (frac1(2)<=frac(2)) then
if frac1(2)<10 then
qpi_out(frac1);
else
qpi_exp(r,frac1);
end;
else
qpi_exp(r,frac);
end;
end; // end_if p*q==1 or q>50
else // e^(r)>1000
qpi_exp(r,frac);
end; // end_if e^(r)<1001
qpi_exp(r,frac)
local frac1;
if r<0 then
qpi_out(frac);
else
frac1:=qpi_approx(LN(r));
frac1(3):=4;
if frac1(2)>qpiEXPLN then
qpi_out(frac);
else
if frac1(2)<=frac(2) then
qpi_out(frac1);
else
qpi_out(frac);
end;
end;
end;
// returns frac(t+1) where
// frac:={p/q, sqrt(p/q), p/q*pi, ln(p/q), e^(p/q)}
// and list:={p,q,t}
qpi_out(list)
local s0="(", s1=")'";
if list(3)==1 then
qpi_outsqrt(list);
else
if list(1)<0 then s0:="-" + s0; end;
if list(3) then s1:=")" + s1; end;
case
if list(3)==2 then s1:=")*π'"; end;
if list(3)==3 then s0:="LN(" + s0; end;
if list(3)==4 then s0:="e^(" + s0; end;
end;
s0:="'" + s0;
if list(2)==1 then
expr(s0 + abs(list(1)) + s1);
else
expr(s0 + abs(list(1)) + "/" + list(2) + s1);
end;
end;
qpi_outsqrt(list)
local ab1, ab2;
local s0="'";
if list(1)<0 then s0:=s0+"-"; end;
ab1:=qpi_asqrtb(abs(list(1)));
ab2:=qpi_asqrtb(list(2));
if ab1(1)<>ab2(1) then
if ab2(1)==1 then
s0:=s0 + ab1(1) + "*";
else
s0:=s0 + "(" + ab1(1) + "/" + ab2(1) + ")*";
end;
end;
s0:=s0 + "√(";
if ab2(2)==1 then
s0:=s0 + ab1(2);
else
s0:=s0 + ab1(2) + "/" + ab2(2);
end;
expr(s0+")'");
// returns {a,b} where n=a*sqrt(b)
qpi_asqrtb(n)
local div,quo,rem,num,den,nodd;
if n>qpiMAXINT then RETURN({1,n}); end;
div:=1;
num:=n;
den:=4;
nodd:=3;
repeat
quo:=IP(num/den);
rem:=num MOD den;
if rem==0 then
div:=div*(IP(nodd/2)+1);
num:=quo;
else
nodd:=nodd+2;
den:=den+nodd;
end;
until (quo==0) OR (nodd>qpiMAXINT) end;
RETURN({div,num});
// returns {p,q,0} where r=p/q
qpi_approx(r)
local num,inum,den,iden;
local p0,q0,p1,q1,p2,q2;
local quo,rem;
if NOT(r) then RETURN({0,1,0}); end;
num:=abs(r);
inum:=IP(num);
den:=1;
while num-inum do
num:=num*10;
den:=den*10;
inum:=IP(num);
end;
iden:=den;
rem:=den; den:=num;
p1:=0; p2:=1;
q1:=1; q2:=0;
repeat
p0:=p1; p1:=p2;
q0:=q1; q1:=q2;
num:=den; den:=rem;
quo:=IP(num/den);
rem:=num MOD den;
p2:=quo*p1+p0;
q2:=quo*q1+q0;
until 10^qpiDIGITS*abs(inum*q2-iden*p2)<iden*p2 end;
if (r>0) then
RETURN({p2,q2,0});
else
RETURN({−p2,q2,0});
end;
#cas
qpi_symb(f):=
begin
local j,n,g,r;
if (type(f) <> DOM_SYMBOLIC) then return(f); end;
n:=dim(f)+1;
for j from 2 to n do
g:=f[j];
if (type(g) == DOM_FLOAT) then
r:=QPI(g);
f[j]:=r;
end;
if (type(g) == DOM_SYMBOLIC) then
r:=qpif(g);
f[j]:=r;
end;
end;
return(f);
end;
#end
11-17-2017, 03:36 PM
To Tim's point,
An unaware student, seeking an exact representation of these numbers might not quickly think of QPI as an applicable command name for this purpose. As a command name, QPI doesn't convey its purpose very well.
Command names that have some essence of their purpose have search advantages, and are more intuitive when encountered in programs. QPI could be part of the help description for historical context, but as a command name, it's not the best.
11-17-2017, 03:43 PM
(11-17-2017 03:36 PM)DrD Wrote: [ -> ]An unaware student, seeking an exact representation of these numbers might not quickly think of QPI as an applicable command name for this purpose.
So, EXACT() should be appropriate for this purpose.
11-17-2017, 03:50 PM
(11-17-2017 03:43 PM)Didier Lachieze Wrote: [ -> ](11-17-2017 03:36 PM)DrD Wrote: [ -> ]An unaware student, seeking an exact representation of these numbers might not quickly think of QPI as an applicable command name for this purpose.
exact() currently already exists as a command. Moreover, it only converts to fractional form, unless I am mistaken. If we wish to use EXACT, (all uppercase, to be treated differently from all lowercase exact()) then it could work. However, there are many forms that will not be handled by QPI (at least not currently): SIN(2), 2+SQRT(3), 1/PI, etc. So EXACT seems to be overreaching as far as names go.
11-17-2017, 03:55 PM
try with 2.30258509299 as result of approx(LN(10))
exact(2.30258509299) returns (bot Home and CAS) 1944167/844341
QPI(2.30258509299) and ->Qπ(2.30258509299) return LN(10).
Note: QPI both in Home and CAS, ->Qπ for now only in Home.
Onestly, I prefer the output of QPI, and I think we could keep both commands separated and for different goals...
However, maybe also a (all caps) EXACT() could be a good idea.
