11-28-2017, 10:23 AM
11-29-2017, 05:59 AM
(11-28-2017 10:23 AM)ggauny@live.fr Wrote: [ -> ]Yes, QPI without the arrow on the left, it is faster to type.
Until it's officially renamed, create your own alias for →Qπ called "qpi". It's not only easier to type but it also works in CAS:
11-29-2017, 06:34 AM
(11-29-2017 05:59 AM)Joe Horn Wrote: [ -> ]Until it's officially renamed, create your own alias ...
Thanks for the tip. I called it "CantorTurningInHisGrave" ;-)
11-29-2017, 09:34 AM
Hi Joe,
Thanks for this tips.
11-29-2017, 04:21 PM
But be aware that a soft reset with <On-Symb> will mess up the "defines" (input variables will become unchecked), and sometimes the entire "define" function will even disappear. Until this is fixed, I prefer to have qpi as a one-line program in the catalog.
11-30-2017, 01:43 AM
(11-29-2017 04:21 PM)Helge Gabert Wrote: [ -> ]But be aware that a soft reset with <On-Symb> will mess up the "defines" (input variables will become unchecked), and sometimes the entire "define" function will even disappear. Until this is fixed, I prefer to have qpi as a one-line program in the catalog.
The entire function will only disappear if you haven't turned the calculator off and back on between creating the definition and pressing On+Symb. Toggling power saves Prime's RAM (where Defines reside) to flash, so it's always a good idea to do that right after doing anything that you don't want to lose (e.g. a Define).
11-30-2017, 02:35 AM
One could also make a program to create user defined functions:
HVars("qpi",{"X"}):='→Qπ(X)'
11-30-2017, 03:51 PM
Yes - - this approach (via HVars) seems to hold everything together, even after a soft reset.
