05-10-2017, 10:02 AM
Bonjour,
After fresh windows 10 64 bit install on my Asus laptop (UX501JW), I cannot install the last HP prime virtual calculator.
During the install process, a windows ask me for a file "HP_Prime_Virtual_calculator.exe" file.
If I cancel the request the process stop with attached log file.
In the recent past I was a problem with Hide/Undhide Tittle Bar (with the last windows installation and also in my desktop) :
1) HP virtual calculator calculator doesn't memorize the status (Hide/Unhide) of the Title bar, always Unhide.
2) When I hide the status bar the calculator picture shift below 0,5 cm an double the bottom line of HP screen calculator.
No problem with HP connectivity kit last issue installation.
Thank for your attention.
Installation Log File
[083C:2058][2017-05-10T07:19:20]i001: Burn v3.9.1006.0, Windows v10.0 (Build 15063: Service Pack 0), path: C:\Users\m0462\Downloads\HP_Prime_Virtual_Calculator_2016_12_08.exe, cmdline: ''
[083C:2058][2017-05-10T07:19:21]i000: Setting string variable 'WixBundleLog' to value 'C:\Users\m0462\AppData\Local\Temp\HP_Prime_Virtual_Calculator_20170510071921.log'
[083C:2058][2017-05-10T07:19:21]i000: Setting string variable 'WixBundleOriginalSource' to value 'C:\Users\m0462\Downloads\HP_Prime_Virtual_Calculator_2016_12_08.exe'
[083C:2058][2017-05-10T07:19:21]i000: Setting string variable 'WixBundleOriginalSourceFolder' to value 'C:\Users\m0462\Downloads\'
[083C:2058][2017-05-10T07:19:21]i052: Condition '((VersionNT >= v5.2) AND (ServicePackLevel >= 2)) OR (VersionNT >= v6.0)' evaluates to true.
[083C:2058][2017-05-10T07:19:21]i000: Setting string variable 'WixBundleName' to value 'HP Prime Virtual Calculator'
[083C:0CB8][2017-05-10T07:19:21]i000: Setting version variable 'WixBundleFileVersion' to value '1.31.11226.0'
[083C:2058][2017-05-10T07:19:21]i100: Detect begin, 2 packages
[083C:2058][2017-05-10T07:19:21]i000: File search: MFC120_Version_x86, did not find path: C:\Windows\system32\mfc120.dll
[083C:2058][2017-05-10T07:19:21]i101: Detected package: vcredist_x86EXE, state: Absent, cached: None
[083C:2058][2017-05-10T07:19:21]i101: Detected package: PrimeEmulatorMSI, state: Absent, cached: None
[083C:2058][2017-05-10T07:19:21]i199: Detect complete, result: 0x0
[083C:0CB8][2017-05-10T07:19:26]i000: Setting numeric variable 'EulaAcceptCheckbox' to value 1
[083C:2058][2017-05-10T07:19:26]i200: Plan begin, 2 packages, action: Install
[083C:2058][2017-05-10T07:19:26]w321: Skipping dependency registration on package with no dependency providers: vcredist_x86EXE
[083C:2058][2017-05-10T07:19:26]i000: Setting string variable 'WixBundleLog_vcredist_x86EXE' to value 'C:\Users\m0462\AppData\Local\Temp\HP_Prime_Virtual_Calculator_20170510071921_0_vcredist_x86EXE.log'
[083C:2058][2017-05-10T07:19:26]i000: Setting string variable 'WixBundleRollbackLog_PrimeEmulatorMSI' to value 'C:\Users\m0462\AppData\Local\Temp\HP_Prime_Virtual_Calculator_20170510071921_1_PrimeEmulatorMSI_rollback.log'
[083C:2058][2017-05-10T07:19:26]i000: Setting string variable 'WixBundleLog_PrimeEmulatorMSI' to value 'C:\Users\m0462\AppData\Local\Temp\HP_Prime_Virtual_Calculator_20170510071921_1_PrimeEmulatorMSI.log'
[083C:2058][2017-05-10T07:19:26]i201: Planned package: vcredist_x86EXE, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: None, cache: Yes, uncache: No, dependency: None
[083C:2058][2017-05-10T07:19:26]i201: Planned package: PrimeEmulatorMSI, state: Absent, default requested: Present, ba requested: Present, execute: Install, rollback: Uninstall, cache: Yes, uncache: No, dependency: Register
[083C:2058][2017-05-10T07:19:26]i299: Plan complete, result: 0x0
[083C:2058][2017-05-10T07:19:26]i300: Apply begin
[1920:188C][2017-05-10T07:19:30]i360: Creating a system restore point.
[1920:188C][2017-05-10T07:19:30]i361: Created a system restore point.
[1920:188C][2017-05-10T07:19:30]i000: Caching bundle from: 'C:\Users\m0462\AppData\Local\Temp\{45f6fe44-8e06-48ed-9cea-b9a5a99ce995}\.be\HP_Prime_Virtual_Calculator.exe' to: 'C:\ProgramData\Package Cache\{45f6fe44-8e06-48ed-9cea-b9a5a99ce995}\HP_Prime_Virtual_Calculator.exe'
[1920:188C][2017-05-10T07:19:30]i320: Registering bundle dependency provider: {45f6fe44-8e06-48ed-9cea-b9a5a99ce995}, version: 1.31.11226.0
[083C:0D5C][2017-05-10T07:19:30]w341: Prompt for source of container: WixAttachedContainer, path: C:\Users\m0462\Downloads\HP_Prime_Virtual_Calculator.exe
[083C:0D5C][2017-05-10T07:22:22]e054: Failed to resolve source for file: C:\Users\m0462\Downloads\HP_Prime_Virtual_Calculator.exe, error: 0x80070642.
[083C:0D5C][2017-05-10T07:22:22]e000: Error 0x80070642: Failed while prompting for source (original path 'C:\Users\m0462\Downloads\HP_Prime_Virtual_Calculator.exe').
[083C:0D5C][2017-05-10T07:22:22]e311: Failed to acquire container: WixAttachedContainer to working path: C:\Users\m0462\AppData\Local\Temp\{45f6fe44-8e06-48ed-9cea-b9a5a99ce995}\9368D48A6F9366DBC9931376F4DE88544CAB47B2, error: 0x80070642.
[083C:2058][2017-05-10T07:22:22]e000: Error 0x80070642: Failed while caching, aborting execution.
[1920:188C][2017-05-10T07:22:22]i330: Removed bundle dependency provider: {45f6fe44-8e06-48ed-9cea-b9a5a99ce995}
[1920:188C][2017-05-10T07:22:22]i352: Removing cached bundle: {45f6fe44-8e06-48ed-9cea-b9a5a99ce995}, from path: C:\ProgramData\Package Cache\{45f6fe44-8e06-48ed-9cea-b9a5a99ce995}\
[083C:2058][2017-05-10T07:22:22]i399: Apply complete, result: 0x80070642, restart: None, ba requested restart: No
