04-18-2017, 05:00 PM
Every time I select a CAS command in HOME view I get "Error: Syntax Error" and i have to remove "CAS." from the command i select, is this a common problem or do I have the wrong firmware or something?
(04-18-2017 05:00 PM)tdh79 Wrote: [ -> ]Every time I select a CAS command in HOME view I get "Error: Syntax Error" and i have to remove "CAS." from the command i select, is this a common problem or do I have the wrong firmware or something?
(04-19-2017 01:44 AM)toml_12953 Wrote: [ -> ](04-18-2017 05:00 PM)tdh79 Wrote: [ -> ]Every time I select a CAS command in HOME view I get "Error: Syntax Error" and i have to remove "CAS." from the command i select, is this a common problem or do I have the wrong firmware or something?
Have you tried CAS(yourcommand) rather than CAS.yourcommand?
Don't ask me why. The interface between CAS and Home is inconsistent.
Tom L
(04-19-2017 03:04 PM)Tim Wessman Wrote: [ -> ](04-18-2017 05:00 PM)tdh79 Wrote: [ -> ]Every time I select a CAS command in HOME view I get "Error: Syntax Error" and i have to remove "CAS." from the command i select, is this a common problem or do I have the wrong firmware or something?
The latest is the one I would recommend. That is 2016.12.08 r11226
I do not see any behavior you report with that. What do you have?
(04-20-2017 01:32 PM)Han Wrote: [ -> ](04-19-2017 03:04 PM)Tim Wessman Wrote: [ -> ]The latest is the one I would recommend. That is 2016.12.08 r11226
On the virtual calc, if you press the toolbox button > CAS > Calculus > diff then the command line shows CAS.diff()
(04-20-2017 01:42 PM)tdh79 Wrote: [ -> ]even though their both set to RPN
(04-20-2017 03:53 PM)Tim Wessman Wrote: [ -> ](04-20-2017 01:42 PM)tdh79 Wrote: [ -> ]even though their both set to RPN
Well, that information would have been pretty important at the start.
Yes, this is the current behavior. No, it probably shouldn't be doing that. I'll file an issue to look at why it is misbehaving in RPN mode here.
(04-24-2017 07:16 AM)retoa Wrote: [ -> ]What did you choose as "digit grouping" in the home settings?
Normally you have this problem if in the home settings you are using the , instead of the . as a decimal point i.e. if you select 123456,789
