The PRINT() uses the terminal, and does not use pixel-based character positioning. TEXTOUT commands do.
Additionally, with TEXTOUT, more font sizes, text color, and background color are available. You can put characters anywhere you want them. Using PIXON, and PIXOFF you could even construct your own characters, (which I found useful to display 'rotated' text around the perimeter of the outer resistance circle for a Smith Chart application). These pixel based commands do require familiarity with graphic variable usage, such as RECT_P(), and BLIT_P().
Designing an output display can be more versatile when using the graphic feature set. It just comes with more overhead than the simple PRINT() command.
// RegPolygon()
// 4/7/2016 DrD
// Regular polygon, (equal sides, and equal angles)
// Finds:
// 1. Side length (a); a:=2*r*TAN(180/n), a:=2*R*SIN(180/n), a:=SQRT((4*A*TAN(180/n))n)
// 2. Inradius (apothem: Distance from center to midpoint of a side) (r); r:=1/2*a*COT(180/n), r:=R*COS(180/n), r:=SQR(A*n*TAN(180/n))
// 3. Circumradius (Distance from center to a vertex) (R); R:=1/2*a*CSC(180/n), R:=r*SEC(180/n), R:=SQRT(2*A/(n*SIN(360/n)))
// 4. Area (A); A:=1/4*n*a^2*COT(180/n), A:=n*r^2*TAN(180/n), A:=1/2*n*R^2*SIN(180/n)
// 5. Perimeter (p); p:=n*a, p:=2*n*R*sin(180/n)
// Provide the number of sides (n), select one of the unknowns (a,r,R,A), and it's dimension.
EXPORT RegPolygon()
LOCAL a,r,p,R,A;
LOCAL n,k,Sidelength,Apothem,Circumradius,Area,Perimeter; // n=number of sides, k=known parameter, cb(x)=checkboxes for (a,r,R,A,p)
LOCAL white:=rgb(255,255,255),
black:=rgb(0,0,0),
red:=rgb(255,0,0),
green:=rgb(0,255,0),
blue:=rgb(0,0,255);
HAngle:=1;
input ({ {n, [0], {60,20,0}},
{k, [0], {60,20,1}},
{Perimeter, 4, {45,21,3}},
{Apothem, 4, {75,21,3}},
{Circumradius, 4, {45,21,4}},
{Area, 4, {75,21,4}},
{Sidelength, 4, {45,21,5}} },
"Regular Polygon Parameters",
{"Number of sides ", "(Check box) Dimension"},
{"How many sides?", "(Checked box) Value?"},
{6,5},
{6,5} );
IF Perimeter THEN
a:=k/n;r:=1/2*a*COT(180/n);R:=1/2*a*CSC(180/n);A:=1/4*n*a^2*COT(180/n);
IF Sidelength THEN
a:=k;r:=1/2*a*COT(180/n);R:=1/2*a*CSC(180/n);A:=1/4*n*a^2*COT(180/n);
END; // Sidelength given
IF Apothem THEN
r:=k;a:=2*r*TAN(180/n);R:=r*SEC(180/n);A:=n*r^2*TAN(180/n);
END; // Inradius (Distance from center to Apothem (midpoint of side))given
IF Circumradius THEN
R:=k;a:=2*R*SIN(180/n);r:=R*COS(180/n);A:=1/2*n*R^2*SIN(360/n);
END; // Circumradius (Distance from center to vertex) given
IF Area THEN
A:=k;a:=SQRT((4*A*TAN(180/n))/n);r:=SQRT(A/(n*TAN(180/n)));R:=SQRT(2*A/(n*SIN(360/n)));
END; // Area given
p:=n*a; // Perimeter
// == Data display ==
DIMGROB_P(G1,320,240); // Define working space (full screen)
RECT(G1); // Clear working space
LINE_P(G1,160,120,100*COS(0)+160,100*SIN(0)+120,green); // Circum Radius line
ARC_P(G1,160,120,100,green); // Draw unit circumcircle (radius 100)
TEXTOUT_P("Circumradius = " + ROUND(R,2),G1,165,105,2,green); // Label Circumradius
LINE_P(G1,160,120,r/R*100*COS(180/n)+160,r/R*100*SIN(180/n)+120,blue); // Inradius (Apothem) line
ARC_P(G1,160,120,r/R*100,blue); // Draw unit Inircle (radius r/R*100)
TEXTOUT_P("Apothem = " + ROUND(r,2),G1,r/R*100*COS(180/n)+100,r/R*100*SIN(180/n)+120,2,blue); // Label Apothem radius
TEXTOUT_P("Number of Sides = " + n,G1,100,4); // Label Number of Sides
TEXTOUT_P("Area = " + ROUND(A,2),G1,120,220); // Label Number of Area
TEXTOUT_P("Side Length = " + ROUND(a,2),G1,200,r/R*100*SIN(180/n)+20,2,red); // Label Side Length
TEXTOUT_P("Ext. Angles = " + ROUND((180-360/n),1) + "°",G1,200,20,2,red); // Label Ext Angles
TEXTOUT_P("Int. Angles = " + ROUND((360/n),1) + "°",G1,r/R*100*COS(180/n)+20,r/R*100*SIN(180/n)+10,2,red); // Label Int Angles
TEXTOUT_P("Perimeter = " + ROUND(p,2),G1,10,25,2,red); // Label Number of Sides
FOR I from 0 to 360 STEP 360/n do
LINE_P(G1,100*COS(I)+160,100*SIN(I)+120,100*COS(I+360/n)+160,100*SIN(I+360/n)+120,red); // n Sides
BLIT_P(G0,0,0,320,240,G1,0,0,320,240); // Transfer working space to display space
WAIT;
Print;
Print( " SUMMARY:" + CHAR(10) + CHAR(10) +
" Number of sides = " + n + CHAR(10) +
" Side length = " + ROUND(a,2) + CHAR(10) +
" Perimeter = " + ROUND(p,2) + CHAR(10) +
" Area = " + ROUND(A,2) + CHAR(10) +
CHAR(10) +
" Circumradius = " + ROUND(R,2) + CHAR(10) +
" Inradius (Apothem) = " + ROUND(r,2) + CHAR(10) +
CHAR(10) +
" Interior Angles = " + 360/n + "°" + CHAR(10) +
" Exterior Angles = " + (180-360/n) + "°" );
