Programming questions
04-06-2016, 03:43 PM (This post was last modified: 04-06-2016 03:45 PM by periappi.)
I've got some weird issues with my program, so here are some of them :
1) I cannot set the space width right :
HP Prime Emulator (the same on the calculator) :
[Image: 227964bug.png]
The code see by the program editor in the emulator :
[Image: 412776Capture.png]
HP Connection Kit (no problem here) :
[Image: 41873422ok.png]
2) Is there a way so I can put a big text into a PRINT() without it crashs ?
Thanks !
04-06-2016, 10:35 PM
RE: Programming questions
If you would like to create your own screens, you might find textout_p() useful. It will require manipulating graphic screens, most likely, but well worth the effort.
-Dale-
04-07-2016, 08:03 AM
The Kit and program editor using a monospaced font, PRINT and TEXTOUT adjust the text according to the character, there is no way to modify this feature.
Viga C | TD | FB
04-07-2016, 11:29 AM
The PRINT() uses the terminal, and does not use pixel-based character positioning. TEXTOUT commands do.
Additionally, with TEXTOUT, more font sizes, text color, and background color are available. You can put characters anywhere you want them. Using PIXON, and PIXOFF you could even construct your own characters, (which I found useful to display 'rotated' text around the perimeter of the outer resistance circle for a Smith Chart application). These pixel based commands do require familiarity with graphic variable usage, such as RECT_P(), and BLIT_P().
Designing an output display can be more versatile when using the graphic feature set. It just comes with more overhead than the simple PRINT() command.
Here's a small program that uses both methods, perhaps useful for ideas:
//  RegPolygon()
//  4/7/2016  DrD
//  Regular polygon, (equal sides, and equal angles)
//  Finds:
//         1. Side length                                                     (a);  a:=2*r*TAN(180/n), a:=2*R*SIN(180/n), a:=SQRT((4*A*TAN(180/n))n)
//         2. Inradius (apothem: Distance from center to midpoint of a side)  (r);  r:=1/2*a*COT(180/n), r:=R*COS(180/n), r:=SQR(A*n*TAN(180/n))
//         3. Circumradius (Distance from center to a vertex)                 (R);  R:=1/2*a*CSC(180/n), R:=r*SEC(180/n), R:=SQRT(2*A/(n*SIN(360/n)))
//         4. Area                                                            (A);  A:=1/4*n*a^2*COT(180/n), A:=n*r^2*TAN(180/n), A:=1/2*n*R^2*SIN(180/n)
//         5. Perimeter                                                       (p);  p:=n*a, p:=2*n*R*sin(180/n)
//  Provide the number of sides (n),  select one of the unknowns (a,r,R,A), and it's dimension.
EXPORT RegPolygon()
  LOCAL a,r,p,R,A;
  LOCAL n,k,Sidelength,Apothem,Circumradius,Area,Perimeter;  // n=number of sides, k=known parameter, cb(x)=checkboxes for (a,r,R,A,p)
  LOCAL white:=rgb(255,255,255),
        black:=rgb(0,0,0),
        red:=rgb(255,0,0),
        green:=rgb(0,255,0),
        blue:=rgb(0,0,255);
  HAngle:=1;
    input ({ {n, [0], {60,20,0}},
             {k, [0], {60,20,1}},
             {Perimeter, 4, {45,21,3}},
             {Apothem, 4, {75,21,3}},
             {Circumradius, 4, {45,21,4}},
             {Area, 4, {75,21,4}},
             {Sidelength, 4, {45,21,5}} },
             "Regular Polygon Parameters",
             {"Number of sides ", "(Check box) Dimension"},
             {"How many sides?", "(Checked box) Value?"},
             {6,5},
             {6,5} );
  IF Perimeter THEN
    a:=k/n;r:=1/2*a*COT(180/n);R:=1/2*a*CSC(180/n);A:=1/4*n*a^2*COT(180/n);
 IF Sidelength THEN
    a:=k;r:=1/2*a*COT(180/n);R:=1/2*a*CSC(180/n);A:=1/4*n*a^2*COT(180/n);
  END; // Sidelength given
  IF Apothem THEN
    r:=k;a:=2*r*TAN(180/n);R:=r*SEC(180/n);A:=n*r^2*TAN(180/n);
  END; // Inradius (Distance from center to Apothem (midpoint of side))given
  IF Circumradius THEN
    R:=k;a:=2*R*SIN(180/n);r:=R*COS(180/n);A:=1/2*n*R^2*SIN(360/n);
  END;  // Circumradius (Distance from center to vertex) given
  IF Area THEN
    A:=k;a:=SQRT((4*A*TAN(180/n))/n);r:=SQRT(A/(n*TAN(180/n)));R:=SQRT(2*A/(n*SIN(360/n)));
  END;  // Area given
  p:=n*a;  //  Perimeter
//  == Data display ==
DIMGROB_P(G1,320,240);                    //  Define working space (full screen)
RECT(G1);                                 //  Clear working space
  LINE_P(G1,160,120,100*COS(0)+160,100*SIN(0)+120,green);                 //  Circum Radius line
  ARC_P(G1,160,120,100,green);                                            //  Draw unit circumcircle (radius 100)
  TEXTOUT_P("Circumradius   =   " + ROUND(R,2),G1,165,105,2,green);       //  Label Circumradius
  LINE_P(G1,160,120,r/R*100*COS(180/n)+160,r/R*100*SIN(180/n)+120,blue);                            //  Inradius (Apothem) line
  ARC_P(G1,160,120,r/R*100,blue);        //  Draw unit Inircle (radius r/R*100)
  TEXTOUT_P("Apothem   = " + ROUND(r,2),G1,r/R*100*COS(180/n)+100,r/R*100*SIN(180/n)+120,2,blue);   //  Label Apothem radius
  TEXTOUT_P("Number of Sides = " + n,G1,100,4);                                                               //  Label Number of Sides
  TEXTOUT_P("Area = " + ROUND(A,2),G1,120,220);                                                               //  Label Number of Area
  TEXTOUT_P("Side Length  = " + ROUND(a,2),G1,200,r/R*100*SIN(180/n)+20,2,red);                               //  Label Side Length
  TEXTOUT_P("Ext. Angles = " + ROUND((180-360/n),1) + "°",G1,200,20,2,red);                                   //  Label Ext Angles
  TEXTOUT_P("Int. Angles = " + ROUND((360/n),1) + "°",G1,r/R*100*COS(180/n)+20,r/R*100*SIN(180/n)+10,2,red); //  Label Int Angles
  TEXTOUT_P("Perimeter = " + ROUND(p,2),G1,10,25,2,red);                                                    //  Label Number of Sides
  FOR I from 0 to 360 STEP 360/n do
    LINE_P(G1,100*COS(I)+160,100*SIN(I)+120,100*COS(I+360/n)+160,100*SIN(I+360/n)+120,red);  //  n Sides
BLIT_P(G0,0,0,320,240,G1,0,0,320,240);    //  Transfer working space to display space
WAIT;
  Print;
  Print( "           SUMMARY:" + CHAR(10) + CHAR(10) +
         "    Number of sides = " + n + CHAR(10) +
         "    Side length = " + ROUND(a,2) + CHAR(10) +
         "    Perimeter = " + ROUND(p,2) + CHAR(10) +
         "    Area = " + ROUND(A,2) + CHAR(10) +
         CHAR(10) +
         "    Circumradius = " + ROUND(R,2) + CHAR(10) +
         "    Inradius (Apothem) = " + ROUND(r,2) + CHAR(10) +
         CHAR(10) +
         "    Interior Angles = " + 360/n + "°" + CHAR(10) +
         "    Exterior Angles = " + (180-360/n) + "°" );
04-07-2016, 01:37 PM
(04-07-2016 11:29 AM)DrD Wrote:
//  RegPolygon()
//  4/7/2016  DrD
//  Finds:
EXPORT RegPolygon()
  LOCAL a,r,p,R,A;
        black:=rgb(0,0,0),
        red:=rgb(255,0,0),
        blue:=rgb(0,0,255);
  HAngle:=1;
             {6,5},
             {6,5} );
  IF Perimeter THEN
 IF Sidelength THEN
  IF Apothem THEN
  IF Area THEN
  END;  // Area given
WAIT;
  Print;
         CHAR(10) +
         CHAR(10) +
This program is very nice! TKS!
Leo
04-07-2016, 05:43 PM
Thanks for the replies, it helps a lot !
PS : the program is awesome !
