Hi All,
Using the HP-71B emulator by Chris, I discovered that I can use several DIM statements to increase the size of an array. The succesive DIM statements do not erase existing array values stored after using the previous DIM statements.
My question is. Is this a feature of the emuator only? I have a physical 71B in my house but cannot seem to find it! That's why I am asking the question.
Also, if you are a psychic, can you please tell me where to find my HP-71B calculator?
Namir
(02-26-2024 11:53 AM)Namir Wrote: [ -> ]My question is. Is this a feature of the emuator only?
No. This is what the manual has to say about redimensioning arrays:
If an array’s dimensions are reduced, some elements will of course be lost. Otherwise, existing elements remain intact, although they will probably appear to have been rearranged. Array element values are stored row-by-row. That is, the first row, last column value is followed by the second row, first column value. If an array’s dimensions are expanded, all new elements are initialized to zero."
(02-26-2024 11:53 AM)Namir Wrote: [ -> ]Also, if you are a psychic, can you please tell me where to find my HP-71B calculator?
Unfortunately not...
Max
Despite the apparent conflict between what the manual says and your observed results, I am confident the Emu71/Win is behaving exactly the same as a real 71B when it comes to how statements behave. Emu71 is emulating the 71b h/w and runs the original ROMs, it's not a simulator with some functions implemented possibly in a different or enhanced way. So it's likely you are simply expanding the matrices in a way that does not 'remove' any elements, i.e. never decreasing any matrix dimension.
As for your 71B, I can't say for sure, but I can narrow it down to one of your eBay buyers.
You're welcome!
(02-26-2024 01:17 PM)rprosperi Wrote: [ -> ]Despite the apparent conflict between what the manual says and your observed results, I am confident the Emu71/Win is behaving exactly the same as a real 71B when it comes to how statements behave. Emu71 is emulating the 71b h/w and runs the original ROMs, it's not a simulator with some functions implemented possibly in a different or enhanced way. So it's likely you are simply expanding the matrices in a way that does not 'remove' any elements, i.e. never decreasing any matrix dimension.
You're welcome!
I sold several HP-71B on eBay but I knw I had one more with some nice modules too. Problem is that machine is doing a Houdini number of me!
Namir
(02-26-2024 12:24 PM)Maximilian Hohmann Wrote: [ -> ]Hello,
"If an array’s dimensions are reduced, some elements will of course be lost. Otherwise, existing elements remain intact, although they will probably appear to have been rearranged. Array element values are stored row-by-row. That is, the first row, last column value is followed by the second row, first column value. If an array’s dimensions are expanded, all new elements are initialized to zero."
Max
Thank you for the verification.
(02-26-2024 04:56 PM)Namir Wrote: [ -> ]I sold several HP-71B on eBay but I knw I had one more with some nice modules too. Problem is that machine is doing a Houdini number of me!
Namir
The most effective solution is to stop looking for the 71B and look for something else, it should turn up quickly.
After many years of training (“where is my phone?”, “where are my spectacles?”, “where are my keys?”, “do something!”) I have developed some modest abilities - but I failed a few times as well, for example when her phone appeared only after the snow melted down in spring or her watch had to spend a few years in the composter, so don’t get overexcited.
Anyway. From what I can see, the calculator is in your study or bedroom, possibly living room. If not, check the pantry. The attic, cellar and garage are worth a try, too. In any case, it’s somewhere in your house. Or very close.
As a compensation for my services, I call dibs on everything HP you’ll find and you consider lost or just forgot about it.
Good luck!
My little devil says I should wait. My little angel says I should help now:
Ok. The HP71b has two hiding places, it's also mentioned in the manual:
In or under a magazine or book.
In its hard case, still because of the last journey.
Good luck!
rprosperi Wrote:So it's likely you are simply expanding the matrices in a way that does not 'remove' any elements, i.e. never decreasing any matrix dimension.
Not exactly. You
can decrease any matrix dimension as long as the new
total number of elements is equal or bigger than the number of elements before redimensioning.
For instance, assuming
OPTION BASE 1, if you redimension a
10x10 array to
20x5 (thus
decreasing one dimension from
10 to
5) you won't lose any elements, as the total number of elements (
10x10 =
100 =
20x5) remains the same.
In short, decreasing the
total number of elements is what will lose you some elements, not decreasing a dimension
per se.
Regards<
V.
Thanks for clarifying this Valentin! After your note, I more closely re-read the manual portion and although I can see what is said there is not inconsistent, your way of stating it was far more clear.
I suppose this means element [2,1] of the new matrix is equal to element [1,6] of the original, and so one, from the storage being row-oriented, is that correct? I'd normally try it, at home there are always 2-3 71B's within reach, but I'm away in my Florida home for a winter break, and convinced myself to not take a 71 along - 'Why bother, I won't need it while there for sure...' was my thinking... HAH!
The array allocation on the 71B is indeed dynamic, that is you can increase/decrease the size of the array with memory taken from/released to the free memory pool.
In other HP BASIC implementations, such as the 75C, Series 80 or RMB, the array is allocated only once (sometimes in the "pre-run" phase) with the DIM statement and constant (static) dimensions, i.e. DIM A(10,10) not N= 10 @ DIM A(N,N).
In these implementations, the REDIM statement can be used to change the array dimensions within the limits of the DIM memory allocation, and the elements are then preserved, with a significant difference versus the 71B:
HP-71B HP-75C
10 OPTION BASE 1 10 OPTION BASE 1
20 DIM A(3,3) 20 DIM A(3,3)
30 MAT A=(1) 30 MAT A=(1)
40 DIM A(2,2) 40 REDIM A(2,2)
50 DIM A(3,3) 50 REDIM A(3,3)
60 MAT PRINT A; 60 MAT PRINT A;
1 1 1 1 1 1
1 0 0 1 1 1
0 0 0 1 1 1
J-F
(from a hypothetical future "Lectures on HP BASIC" :-)
(02-27-2024 07:59 AM)J-F Garnier Wrote: [ -> ]The array allocation on the 71B is indeed dynamic, that is you can increase/decrease the size of the array with memory taken from/released to the free memory pool.
HP-71B HP-75C
1 1 1 1 1 1
1 0 0 1 1 1
0 0 0 1 1 1
J-F
Thanks for clarifying the difference on how to implement dynamic arrays between the 71B and the 75C.
attachment=13333]
Long time ago one of your 71B's landed at my place. It was not working and had suffered some abuse.
The bezel was so bad, so I removed it. I had to rebuild the Keyboard ( polisched the Key's) fix
the connection between the two halves, and then it worked again. It had 3 front EPROM modules.
I rewired one to support a 64k EPROM, and it became my Favorite 71B ! [
attachment=13333]
(02-26-2024 11:53 AM)Namir Wrote: [ -> ]can you please tell me where to find my HP-71B calculator?
Lets think in problem solving (first strong logical).
NOTHING psychological. Only standard project management thinking and issue solving.
example
https://sixsigmadsi.com/what-is-an-is-is...nduct-one/
IS.........................................IS-NOT
dry place................................wet place
no particle exposed....................................................-> .. in the house? or NOT in the garden house
.............................................in sight of spouse..........-> .. NOT the bedroom
like other around the house.........................................-> .. oh no, start a wide search
So, feed the problem solving matrice then you find the part in 2-3 weeks (can take time).
except erratic (non logical) happenings are sometime there (drunkness, showing off to the good looking female neighbour..) with any outcome and anything was found anywhere (in neighbour house, in the garden house). However, these others experienced happenings (lets call them friendly "best practice") should be introduced into the matrice, too.
Let inform us of the outcome.
"Also, if you are a psychic, can you please tell me where to find my HP-71B calculator?"
What does Alexa, ChartGPT or Siri say?
(03-05-2024 04:46 PM)KeithB Wrote: [ -> ]"Also, if you are a psychic, can you please tell me where to find my HP-71B calculator?"
Thay have NO CLUE!
Namir
(03-05-2024 12:43 PM)RamLab Wrote: [ -> ]Long time ago one of your 71B's landed at my place. It was not working and had suffered some abuse.
Removing the bezel gives your 71B a nice unique touch !
So you wired an external DIP EPROM to a front port CMT module. A picture of your wiring is welcome!
And if you have interesting things in your CMT modules, please share.
Is your 71B display an indication that you have a CMT HP-IL RAM disc unit ?
J-F
Hello J-F, indeed with the later model 71B removing the bezel look nice. The older model has a hole and a notch under the bezel. I tried to re-use the EPROM front modules in various ways. Not having the CMT programmer, I desoldered the EPROM, erased and re-programmed it. Soldered a socket on the CMT front module. Regretfully this gave contact issues, and programming errors. So I ended up rewiring it to a DIP socket. This works fine ! I copied the DATA ACQ HP 82497A in, since I have two HP3421A Units. Indeed, there is an CMT 256k RAM Disl in the loop. and the CMT Display.
attachment=13341]
(03-07-2024 10:27 AM)RamLab Wrote: [ -> ]I tried to re-use the EPROM front modules in various ways. Not having the CMT programmer, I desoldered the EPROM, erased and re-programmed it. Soldered a socket on the CMT front module. Regretfully this gave contact issues, and programming errors. So I ended up rewiring it to a DIP socket. This works fine !
Your module is a HTI not CMT. They use different PCBs:
attachment=13342]
I believe these HTI modules have been made by Zengrange (who built HP71 modules for sure) for HTI-SD, thus the "Made in England".
I once tried to program a HTI module with the CMT programmer but it failed. I was told that others did succeed so it may be unreliable, and your re-use of the HTI module is great !
J-F
Edit: I was sure that RamLab wasn't an unknown name for me:
thread-142045-post-142557 , so hi again !
Hello J-F,
After I bought my first HP3421A in 2005, the first HP71B followed fast, and since then I follow the Forum. Got an Registrated Emu71 HP-71B & HP-IL system emulator from you in 2006.
You are right, the M109/M189 ROM's/EPROMS are not by CMT, but by HTI. The ROM module by the way, was made in Singapore, and uses an HP PCB.
