03-08-2024, 01:28 PM
(03-07-2024 12:44 PM)J-F Garnier Wrote: [ -> ]I once tried to program a HTI module with the CMT programmer but it failed. I was told that others did succeed so it may be unreliable, and your re-use of the HTI module is great !
Yes, I've been able to successfully burn the HTI modules using the CMT programmer, many times (10?). But these modules seem to need a rather long amount of time to be properly erased (30 mins) so that could be the problem you had. I honestly never use the 'check if blank' procedure described in the manual, I just erase for a long time (maybe my EPROM eraser is weak?) and then burn following the CMT procedure.
