I want to run PYILPER on miniconda3 on my windows10 pc.
miniconda3 runs.
But I cant install pyilper.
I type "conda install pyilper". Installation starts. But at the end I got a lot of fault messages like this:
"CondaVerificationError: The package for pyilper located at C:\Users\abcd\miniconda3\pkgs\pyilper-1.8.6-py310_0
appears to be corrupted. The path 'Lib/0/site-packages/pyilper/__pycache__/lifcore.cpython-310.pyc'
specified in the package manifest cannot be found."
Does anybody know where I on the wrong way?
Greetings
Uli
Make sure you use the Windows installer for Python 3.9 and NOT the latest version.
If you used the latest version then uninstall it and then install the appropriate Windows version (I'm using 64 bit) with Python 3.9.
(06-22-2023 07:56 PM)Uli Wrote: [ -> ]Hi,
miniconda3 runs.
Greetings
Uli
I would follow 1:1 the installation instructions
https://github.com/bug400/pyilper/blob/m...INSTALL.md
pyILPER requires:
Python 3.5 or higher
Qt 5.9 or higher with the PyQt5 language bindings or Qt 6.3 with the PySide6 language bindings
The Python bindings for either Qt Webkit or Qt Webengine
Pyserial 2.7 or higher
LIFUTILS (the most recent version)
Then having a look at miniconda3 and what additional packages has to be installed with it for achieving the pyilper requirements.
Thank you dmh and thank you floppy.
I made a new installation with (not the newest) version 3.9 and by following the instruction, you mentioned, and it works at first try.
Greetings
Uli
There was an incompatibility of the my pyILPER packages for Python3.10 with the MINICONDA release of April this year. I did a rebuild of the packages and the installation should now be fine on Windows.
Joachim
