In the case of the former, the link simply had an extra trailing ")" character.
In the case of the latter, where do you see the broken 'contact the curator' link?
The 'Contact us' link in the bottom left of every page seems to work fine.
Does this link work for you?
https://www.hpmuseum.org/forum/contact.htm
It leads to a page containing the following HTML:
PHP Code:
<!DOCTYPE html>
<html lang="en">
<head>
<meta charset="UTF-8">
<meta name="viewport" content="width=device-width, initial-scale=1">
<link rel="stylesheet" href="/pages.css" type="text/css">
<title>Error</title>
</head>
<body>
<div class="single">
<h1>Page Not Found!</h1>
<ul>
<li>If you just clicked on a link in the museum, please <a href="contact.htm">contact the curator</a> and tell him how you got here.
</li>
<li>If you got this error in response to an URL you typed, please check your spelling.</li>
<li>If you go this error when to trying to access the museum via an external web page, please report the error to the author of that page.</li>
</ul>
<p>You can use your browser's back button to return to the previous page or you can:</p>
<p><a href="/"><img src="/gto.gif" width="39" height="34" class="nav" alt=""> Go to the museum's main exhibit hall</a><br>
</p>
</div>
</body>
</html>
The "contact the curator" link leads to the same URL.
The page looks something like this:
Page Not Found!
» If you just clicked on a link in the museum, please
contact the curator and tell him how you got here.
» If you got this error in response to an URL you typed, please check your spelling.
» If you go this error when to trying to access the museum via an external web page, please report the error to the author of that page.
OK, now I get it, you mean the link right on the error page.
That link is bad, as the correct link is "https://www.hpmuseum.org/contact.htm" without "/forum" in the middle. This probably changed when Dave was updating the site's format/style over the past 2 years.
I'm sure he'll see this and fix the url in the 'Page not found' page.
Thanks for reporting this.
But to repeat (in case it was lost in the noise) the "Contact us" at the bottom left of every page does work properly.
Thanks! There should be no more page not found recursion.
thanks Dave
the updated contact page link works good on my end
