05-16-2021, 01:14 PM
While beeing disapointed due to large cpu throttle in HPPL, when python came on the Prime I could not resist ...
So I ported my HP41 emulator on the Prime in Python ... see at LINK
Some nice results :
- python is at least 10 times faster than HPPL for casual stuff
- no cpu throttling
- very deep and well done integration of python with prime firmware
- hpprime module very well done (some small bugs ...)
- python is robust on the prime, very few calc reset/reboot
- if you play too long with the emu, when you leave it the prime shut off due to auto off function not taking python execution into account
Only tested on a G2 model ... for G1 you can change some timing in nut.py (near line 790 : adjust 0.30 in hpprime.eval('WAIT(.030)'))
HP PRIME development workflow in micro-python:
You can do it in the 'HP Connectivy Kit/Content/app.hpappdir/' directory
You can also use in the devKit contextual menu 'add a file' in the v/calc. (be sure to 'Sync' before and after).
I make minor changes in v/calc without troubles, editor seems robust. I just does not succeed in using 'signets/marks'. 'goto' lines sometimes does not refresh the display, moving the cursor with arrows sometimes correct this (perhaps 1000 lines is too much ?).
I sometime edit large parts in the virtual calc directly: PC keyboard and mouse are nice at this job.
Only gripes is the lack of 'SHIFT-arrows' to select text.
Actually sometimes the dev kit takes some seconds to react ... just wait.
When in trouble (shadow apps, strange apps...):
As seen somewhere in this forum I do the following:
Some nice results :
- no cpu throttling
- all is at 2.1.14575 (2021 4 28) level (calc is at 2021 5 5 firmware)
- only tested on a pure micro-python app, no use of HPPL wrapper
- v/calc is either physical calculator (connected on the pc) or virtual calculator.
- An important directory on the PC is 'HP Connectivy Kit/Content/app.hpappdir/' in your 'Documents' when developing the app named 'app'. This directory is important because you do not have sync problem with the v/calc. Using directly 'HP Connectivy Kit/Calaculators/app.hpappdir' can lead to sync problem if you use the v/calc and an external editor even one after the other. Try yourself and you will see ... I loose some editing due to this.
- See this directory as a very safe scratchpad
and make your copies from/to v/calc yourself. If you want to be secure: always delete the destination to avoid an erasing when copying. Doing this I never had any problem. But it's only my way and opinion.
- Set your editor to use LF only as end of line, UTF8 and to expand TABs as spaces.
- I never edit directly program on the v/calc with the editor in the dev kit. (It works for HPPL progs, at least in the previous releases, but for python, it is too dangerous).
- I work with 'Content' which is local to the Pc : edit files from here either with the integrated editor or external editor from the file explorer.
- When testing, delete the whole app in the v/calc, then copy from 'Content' to v/calc.
- If you made some change in the v/calc, back up the previous app.hpappdir:
- First do a 'Sync' from the contextual menu of the v/calc.
- I use an 'archives' directory, I move the app.hpappdir from 'Content' to 'Content/archives' and replace.
- Copy back the whole app from v/calc to 'Content' ... edit at leisure ... - Generally I create file.py in the PC in the 'HP Connectivy Kit/Content/app.hpappdir/' directory.
- connect to the dev kit
- make the cleaning (from contextual menu, delete or init)
- disconnect the calc (do not shut off)
- on the calc, make a backup (MEM/Backups,Sauvegardes)
- still on the calc, restore it at once
