Edit:
I did of course forget something IMPORTANT.
in py41.py line 24 or so, after "def loop():" and before "k=0"add proper indented a line "global addonState" I've added that to the description below.
/EDIT
The HP41 emulator certainly is pretty cool. It is however not so easy to remember the assignments of the keys. One solution is to have some notes handy, but that's not really cool.
I tinkered around a little bit to have something available right away, by using the unused estate left and right of the printout. The display of this is toggled on/off by <SHIFT><VIEW>. Have a look at the picture.
In order to make it work you have to manually do some editing yourself. Please use an editor (e.g. notepad++) that is is suitable to edit text files.
1. Unzip the attached AddOn.zip and add the file AddOn.py to your P41e.hpappdir
2. open nuts.py to edit as text file, goto line 918 "def infos(self,c)" add as next line (proper indented) "return" it should look like
PHP Code:
def infos(self,c):
return
col=(0xFF0000,0x00FF00,0x0000FF)[c]
if self.theme==1:
hpprime.fillrect(0,0,20,50,13,0xffffff,0xffffff)
else:
hpprime.fillrect(0,0,20,50,13,0x181818,0x181818)
hpprime.textout(0,0,20,hex(self.stack[0]),col)
3. save nuts.py
4. open Py41.py to edit as text file
5. on top, right after "import hpprime" add a line "import AddOn"
5a.At line 24 or so, after "def loop():" and before "k=0"add proper indented a line "global addonState"
6. at bottom, after "config.init(cpu) add a line "addonState=False"
7. look upwards and find line 68 "elif k==4:" followed by "pass"
6 after that line insert a new line "elif k==9 and display.lE&0x0080:" folowed by "addonState=AddOn.addon(addonState)" followed by "cpu.togshift()" observe the indentation as in the lines already there. That now should look like:
PHP Code:
elif k==4: # Esc key
pass
cpu.togShift()
elif k==10: # Cas key
8. save Py41e.hpappdir and send it to your real and virtual Prime.
I hope I haven't forgotten anything. And remember this help is invoked (toggled) by <SHIFT><VIEW>
I must admit that's not as elegant as the fine art of Olivier, but may be of great help using the 41cx emulator on the Prime.
Olivier, if you read this perhaps it motivates you to include something like this in your distribution.
Günter
