√(5 + (ϕ^2 + 1) - (5×10^5)/((ϕ^2 + 1) + 10^5))
Evaluate the above expression on the wp34s striving to use the least number of steps. You might need to rewrite it in order to do it in less than 12 steps. Notice ϕ is a built-in constant.
Have fun!
My 11 step solution is 41ish.
Let a = phi^2 + 1
let b = 10^5
The expression is sqrt(5 + a - 5b/(a + b)) ... upon simplification we get:
sqrt(5a/(a+b) + a)
The pseudo-code is based on the last equation.
Phi
X^2
INC X
STO Y
EEX 5
5
SQRT
(09-23-2020 09:14 PM)Namir Wrote: [ -> ]My 11 step solution is 41ish.
Namir, thank you very much for your interest! Unfortunately, however,
EEX 5 requires two steps on the wp34s. Also, your solution doesn’t return the
expected result unless I’m mistaken.
Tip: ϕ^2 + 1 = ϕ + 2
Here is a 12-step solution using your simplification:
001:# Φ
002:x²
003:INC X
004:RCL X
005:# 005
006:×
007:RCL L
008:10ᵡ
009:RCL+ Z
010:/
011:+
012:√
Here is the corrected version based on your comments and hint:
Phi
INC X
INC X
STO Y
EEX
5
5
SQRT
(09-24-2020 10:31 AM)Gerson W. Barbosa Wrote: [ -> ]Here is a 12-step solution using your simplification:
Can be done in 11 steps :
001:#Φ
002:x²
003:INC X
004:RCL X
005:# 005
006:STO× Y
007:10ᵡ
008:RCL+ Z
009:/
010:+
011:√
Phi
INC X
INC X
STO Y
EEX
5
5
SQRT
(09-24-2020 08:00 PM)Didier Lachieze Wrote: [ -> ] (09-24-2020 10:31 AM)Gerson W. Barbosa Wrote: [ -> ]Here is a 12-step solution using your simplification:
001:#Φ
002:x²
003:INC X
004:RCL X
005:# 005
006:STO× Y
007:10ᵡ
008:RCL+ Z
009:/
010:+
011:√
And using ordinary wp34s instructions only.
Formidable !
I had to rewrite the original expression and to resort to a somewhat obscure instruction:
√(7 + ϕ - 5/(1 + (ϕ + 2)/10^5))
001:# 007
002:# ϕ
003:+
004:# 005
005:# 002
006:RCL+ L
007:Pa→bar
008:INC X
009:/
010:-
011:√
→ 1.9021605831
That’s an approximation to a mathematical constant which is know to only nine significant digits, according to
OEIS. Anyway, it agrees to Pascal Sebah’s result to 12 significant digits.
(09-24-2020 08:18 PM)Namir Wrote: [ -> ]Here is the corrected version based on your comments and hint:
Phi
INC X
INC X
STO Y
EEX
5
5
SQRT
It looks like my hint was somewhat misleading, as your simplification does allow for an 11-step solution (see Didier’s solution above). Sorry!
Your fourth step should be replaced with FILL (fill up the stack with a constant) as you need an extra copy of Phi on the stack.
It can be done in 10 steps. Any takers?
(09-27-2020 07:07 PM)Gerson W. Barbosa Wrote: [ -> ]It can be done in 10 steps. Any takers?
Ok, then I'll take it! (See solution #2, solution #1 and some variations thereof is what I already had).
1)
√{5||[5(ϕ + 2)/10^5] + ϕ + 2}
[ a||b = ab/(a + b) ]
001:# ϕ
002:# 002
003:+
004:# 005
005:SDR 005
006:RCL× Y
007:# 005
008:||
009:+
010:√
→ 1.902160583101354
2)
√{ϕ + 2 + [0.2 + 20000/(ϕ + 2)]⁻¹}
001:# 002
002:SDR 001
003:# ϕ
004:RCL+ L
005:# 200
006:%T
007:RCL+ Z
008:1/x
009:+
010:√
