01-17-2020, 04:49 PM
Binary-to-decimal number conversion, often needed when working with digital equipment, can require laborious raising to powers and addition. This program, designed for an SR-52 calculator, provides a convenient method of converting 8-, 16-, 24-, and 32-bit words to their decimal equivalents.
To use the program, binary words are entered into the calculator eight bits at a time, most significant bit first. (Since the SR-52 has a 10-digit mantissa, the program ignores the first two digits entered and only operates on the last eight binary digits.) The user then presses the SR-52's user-defined key A, and the program displays the decimal.
Here's a typical 8 -bit conversion:
ignored
1 1 1 1 1 0 1 0 1 0 ← 1) Enter binary number in display
8-bits ← 2) Press A Key
2 3 4 ← 3) Calculator Displays decimal equivalent
To obtain 16-, 24-, and 32-bit conversions, do the above operation for the first eight bits, but for each additional eight bits entered, press the user-defined key B, which will sum that 8-bit conversion with all previous conversions, to a maximum of 32 bits.
The conversion algorithm is shown here in flowchart
[attachment=8020]
and SR-52 program-listing form.
Location Codes Keys
000 - 003 46 11 42 00 *LBL A STO 0
004 - 007 00 00 42 00 0 0 STO 0
008 - 011 03 42 00 04 3 STO 0 4
012 - 015 42 00 05 08 STO 0 5 8
016 - 019 44 00 05 01 SUM 0 5 1
020 - 023 94 44 00 04 +/- SUM 0 4
024 - 027 46 79 01 44 *LBL *6 1 SUM
028 - 031 00 04 43 00 0 4 RCL 0
032 - 035 00 55 01 00 0 ÷ 1 0
036 - 039 95 42 00 01 = STO 0 1
040 - 043 51 78 43 00 SBR *5 RCL 0
044 - 047 04 75 43 00 4 - RCL 0
048 - 051 05 95 42 00 5 = STO 0
052 - 055 06 43 00 01 6 RCL 0 1
056 - 059 75 43 00 02 - RCL 0 2
060 - 063 95 90 68 43 = *if0 *8 RCL
064 - 067 00 06 90 67 0 6 *if0 *7
068 - 071 02 45 43 00 2 y" RCL 0
072 - 075 04 95 44 00 4 = SUM 0
076 - 079 03 43 00 02 3 RCL 0 2
080 - 083 42 00 00 41 STO 0 0 GTO
084 - 087 79 46 67 43 *6 *LBL *7 RCL
088 - 091 00 03 81 46 0 3 HLT *LBL
092 - 095 68 43 00 06 *8 RCL 0 6
096 - 099 90 67 43 00 *if0 *7 RCL 0
100 - 103 02 42 00 00 2 STO 0 0
104 - 107 41 79 46 78 GTO *6 *LBL *5
108 - 111 75 93 05 54 - . 5 )
112 - 115 57 00 52 22 *fix 0 EE INV
116 - 119 52 22 57 42 EE INV *fix STO
120 - 123 00 02 56 46 0 2 *rtn *LBL
124 - 127 12 42 00 00 B STO 0 0
128 - 131 41 00 01 05 GTO 0 1 5
It works by performing repeated divisions by 10, splitting the dividend into integral and fractional parts, and then looking to see if the fractional part is a 1 or 0. If it is a 1, the program raises 2 to appropriate power and sums it into register 03. After the program has looped through eight bits, it recalls register 03 and halts.
source: RCA Engineer, Engineering and Research Notes, Binary-to-decimal conversion program for a programmable calculator, 1977-08/09, pg.76, A.R. Campbell
BEST!
SlideRule
ignored
[attachment=8020]
Location Codes Keys
BEST!
SlideRule
