Forgot to unplug the USB cable and my PC is delivering current even when switched off. So I found my Prime pretty hot much later. Are there any instructions that the Prime should be unplugged when loaded? Like phones stop loading battery when they reach the max load. Or is my Prime malfunctioning?
My Prime was at 0% when it was plugged to the HP charger the other day.
I forgot it plugged for more than 24 hours. I do not recall high temperatures, not even warm, and the battery was fully charged.
Was yours close to a heat source like the computer itself?
(05-17-2014 07:39 PM)jebem Wrote: [ -> ]Was yours close to a heat source like the computer itself?
Hmmm good point Jebem. It was indeed on the computer but... it was powered off.
So no possible heat transfer there.
Is it heating during normal recharge?
(05-17-2014 07:55 PM)Tugdual Wrote: [ -> ]Is it heating during normal recharge?
Usually it gets a little warm (not hot), but I find this normal as the battery is recharging.
I acquire it in February and to be honest I don't use it that much. I believe that I have recharged it no more than 5 times since new.
Probably yours has many more hours of usage and more recharge cycles. I wonder if the battery is developing some sort of fault.
