09-05-2018, 05:05 AM
Pages: 1 2
09-05-2018, 03:55 PM
(09-05-2018 05:05 AM)Tim Wessman Wrote: [ -> ]One last thing to try, can you remove the battery and plug in the USB to power it? Does it start without the battery installed?
Yes.
09-05-2018, 04:17 PM
So that is a "yes, the calcualtor boots"?
If so, your battery is bad I think. Else you could also try getting the calculator all booted up, leaving it plugged in, and replace the battery while running. Leave it for a bit after that and see if it starts charging.
09-05-2018, 05:32 PM
(09-05-2018 04:17 PM)Tim Wessman Wrote: [ -> ]So that is a "yes, the calcualtor boots"?
Hey Tim, I recorded a video.
https://youtu.be/CRE5L1CP-OU
09-06-2018, 09:52 AM
What else can you on diag screen, can you confirm what it thinks its FW version is ?
and perhaps perform the other tests on this screen
Pages: 1 2
