General Software Library
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47
Threads
- (49g) (50g) Water boiling temperature = f(altitude/pressure + temp); Water density (8 Replies)
- (49g 50g) Theoretical Earth gravity g = g(latitude, height), WGS84, GRS80/67 (17 Replies)
- HP49-50G Statistics: Variance (Pop/Sample) & Mean, with frequencies (2 Replies)
- 49G 50G STAT3.8e.hp: Multiple linear regression & Restricted model (9 Replies)
- HP49-HP50: string search in many programs (2 Replies)
- (42S) - (C+N)/N - "(C+N/N) displayed level on spectrum analyzer screen" (0 Replies)
- (12C) Decoder for HP 12c programs (1 Reply)
- (49G) Convert Integer from Integer Base A to Integer Base B (6 Replies)
- (35S) Quick integration (27 Replies)
- [41C,42S] Linear Congruential Generator Programs that generate Binary OEIS sequences (1 Reply)
- (DM42) Harmonic function based on Bernoulli - 32 digits (3 Replies)
- (50G) Digits sum (50g) (8 Replies)
- (42) GTX - Find Antenna Transmit Gain of an earth station during its acceptance test (0 Replies)
- (42) G/T - Find G/T (Antenna+LNA)of an earth station during its field acceptance test (0 Replies)
- (12C) Discounted Payback Period Program (9 Replies)
- (11C) Quadratic Regression (2 Replies)
- (42) QAM - Frequency Bandwidth and Bit Speed Rate (b/s) for QAM Modulation (0 Replies)
- (42) S/N - Shannon-Hartley Equation for telecom. capacity channel under white noise (0 Replies)
- (42) WSAT - Earth circular orbit radial distance versus angular speed (0 Replies)
- (42) D2L - Minimum far field distance for antenna test range (0 Replies)
- (42) BORDA - Edge illumination angle equation for an on-axis parabolic antenna (0 Replies)
- (42) ZCOAX - Impedance equation for coaxial transmission line (0 Replies)
- (42) BATI - Calc. the distance between 2 discontinuities in the transmission line (0 Replies)
- (42) NF=TK - Converting LNA Noise Figure(dB) <> LNA Noise Temperature (Kelvin) (0 Replies)
- (42) LBDA - solving the guide wavelength (λg) in any transmission line. (0 Replies)
- (42) SQUINT - Antenna main beam deviation for CP offset parabolic antenna (0 Replies)
- (42) TETdB Calculation of an antenna gain level at angular position (0 Replies)
- (42) TOE=RL Converting Antenna VSWR <> Antenna Return Loss (dB) (0 Replies)
- (42) TNULL Reflector antenna radiation pattern 1st null (0 Replies)
- (42) T3dB - Reflector antenna 3dB beamwidth (0 Replies)
