12-21-2022, 03:37 PM
Some basic Linear Congruental Generators that produce binary sequences from OEIS.
These should produce all "known", and may or may not diverge after that- though many are periodic and can be further optimized/explored.
A000035 : Period 2: repeat [0, 1]; a(n) = n mod 2; parity of n.
A011558 : Expansion of (x + x^3)/(1 + x + ... + x^4) mod 2.
A011655 : Period 3: repeat [0, 1, 1].
A011656 : A binary m-sequence: expansion of reciprocal of x^3 + x^2 + 1 (mod 2), shifted by 2 initial 0's.
A060584 : Compare ultimate and penultimate digits of n base 3, i.e., 0 if n mod 3 = floor(n/3) mod 3, 1 otherwise; also 0 if (n mod 9) is a multiple of 4, 1 otherwise.
A074937 : Let c(1) = c(2) = 1, c(n+2) = 1/(c(n+1)+c(n)); then a(n) = (1+sign(c(n)-sqrt(1/2))/2.
A079979 : Characteristic function of multiples of six.
A079998 : The characteristic function of the multiples of five.
A082848 : Duplicate of A078588 "a(n) = 1 if the integer multiple of phi nearest n is greater than n, otherwise 0, where phi = (1+sqrt(5))/2.
A088911 : Period 6: repeat [1, 1, 1, 0, 0, 0].
A093719 : a(n) = (n mod 2)^(n mod 3).
A094875 : a(n)=1 if floor(Pi*10^n) is prime, otherwise a(n)=0.
A095130 : Expansion of (x+x^2)/(1-x^6); period 6: repeat [0, 1, 1, 0, 0, 0].
A097325 : Period 6: repeat [0, 1, 1, 1, 1, 1].
A098457 : Farey Bisection Expansion of sqrt(7).
A100283 : a(n) = floor(p*(n+1)) - floor(p*(n)) - 1 where p = Padovan plastic number = 1.324718... (cf. A060006 Decimal expansion of real root of x^3 - x - 1 (the plastic constant).
A105563 : a(n) = if (exactly 4 Fibonacci numbers exist with exactly n digits) then 1, otherwise 0.
A108357 : Expansion of (1+x^2+x^4)/(1-x^8).
A109720 : Periodic sequence {0,1,1,1,1,1,1} or n^6 mod 7.
A115790 : 1 - (Floor((n+1)*Pi)-Floor(n*Pi)) mod 2.
A121262 : The characteristic function of the multiples of four.
A126565 : a(n) = ceiling(sin(n)*cos(n)).
A131078 : Periodic sequence (1, 1, 1, 1, 0, 0, 0, 0).
A131532 : Period 6: repeat [0, 0, 0, 0, 1, 1].
A131719 : Period 6: repeat [0, 1, 1, 1, 1, 0].
A131735 : Period 6: repeat [0, 0, 1, 1, 1, 1].
A133872 : Period 4: repeat [1, 1, 0, 0].
A141260 : a(n) = 1 if n == {0,1,3,4,5,7,9,11} mod 12, otherwise a(n) = 0.
A144595 : Christoffel word of slope 4/7.
A144596 : Christoffel word of slope 2/7.
A144597 : Christoffel word of slope 3/7.
A144598 : Christoffel word of slope 5/7.
A144599 : Christoffel word of slope 6/7.
A144600 : Christoffel word of slope 2/11.
A144601 : Christoffel word of slope 3/11.
A144602 : Christoffel word of slope 4/11.
A144603 : Christoffel word of slope 5/11.
A144604 : Christoffel word of slope 6/11.
A144605 : Christoffel word of slope 7/11.
A144606 : Christoffel word of slope 8/11.
A144607 : Christoffel word of slope 9/11.
A144608 : Christoffel word of slope 10/11.
A145568 : Characteristic function of numbers relatively prime to 11.
A152822 : Periodic sequence [1,1,0,1] of length 4.
A165211 : Period 8: repeat [0,1,0,1,1,0,1,0].
A166486 : Periodic sequence [0,1,1,1] of length 4.
A168181 : Characteristic function of numbers that are not multiples of 8.
A168182 : Characteristic function of numbers that are not multiples of 9.
A168184 : Characteristic function of numbers that are not multiples of 10.
A168185 : Characteristic function of numbers that are not multiples of 12.
A171386 : The characteristic function of 2 and 3: 1 if n is prime such that either n-1 or n+1 is prime, else 0.
A172051 : Decimal expansion of 1/999999.
A173857 : Expansion of 3/2 in base phi.
A179850 : Characteristic function of numbers that are congruent to {0, 1, 3, 4} mod 5.
A185017 : Characteristic function of 7.
A187074 : a(n) = 0 if and only if n is of the form 3*k or 4*k + 2, otherwise a(n) = 1.
A191152 : [4n*e]-2[2n*e], where [ ]=floor.
A195062 : Period 7: repeat [1, 0, 1, 0, 1, 0, 1].
A204418 : Periodic sequence 1,0,1,..., arranged in a triangle.
A232990 : Period 5: repeat [1,0,0,1,0].
A232991 : Period 6: repeat [1, 0, 0, 0, 1, 0].
A241979 : (0,1) sequence such that lengths of three consecutive runs are always distinct.
A267142 : The characteristic function of the multiples of 9.
A272532 : Single bit representation of the sum of two sinusoids with periods 2 and 2*sqrt(2).
A283437 : Periodic {1, 1, 1, 1, 0, 1, 0, 0, 1, 0, 1, 1}.
A320106 : Möbius transform of A320107 a(n) = A001227(A252463(n)).
A354354 : a(n) = 1 if n is neither a multiple of 2 nor 3, and otherwise 0.
- A000035 : Period 2: repeat [0, 1]; a(n) = n mod 2; parity of n.
- A011558 : Expansion of (x + x^3)/(1 + x + ... + x^4) mod 2.
- A011655 : Period 3: repeat [0, 1, 1].
- A011656 : A binary m-sequence: expansion of reciprocal of x^3 + x^2 + 1 (mod 2), shifted by 2 initial 0's.
- A060584 : Compare ultimate and penultimate digits of n base 3, i.e., 0 if n mod 3 = floor(n/3) mod 3, 1 otherwise; also 0 if (n mod 9) is a multiple of 4, 1 otherwise.
- A074937 : Let c(1) = c(2) = 1, c(n+2) = 1/(c(n+1)+c(n)); then a(n) = (1+sign(c(n)-sqrt(1/2))/2.
- A079979 : Characteristic function of multiples of six.
- A079998 : The characteristic function of the multiples of five.
- A082848 : Duplicate of A078588 a(n) = 1 if the integer multiple of phi nearest n is greater than n, otherwise 0, where phi = (1+sqrt(5))/2.
- A088911 : Period 6: repeat [1, 1, 1, 0, 0, 0].
- A093719 : a(n) = (n mod 2)^(n mod 3).
- A094875 : a(n)=1 if floor(Pi*10^n) is prime, otherwise a(n)=0.
- A095130 : Expansion of (x+x^2)/(1-x^6); period 6: repeat [0, 1, 1, 0, 0, 0].
- A097325 : Period 6: repeat [0, 1, 1, 1, 1, 1].
- A098457 : Farey Bisection Expansion of sqrt(7).
- A100283 : a(n) = floor(p*(n+1)) - floor(p*(n)) - 1 where p = Padovan plastic number = 1.324718... (cf. A060006 "Decimal expansion of real root of x^3 - x - 1 (the plastic constant).
- A105563 : a(n) = if (exactly 4 Fibonacci numbers exist with exactly n digits) then 1, otherwise 0.
- A108357 : Expansion of (1+x^2+x^4)/(1-x^8).
- A109720 : Periodic sequence {0,1,1,1,1,1,1} or n^6 mod 7.
- A115790 : 1 - (Floor((n+1)*Pi)-Floor(n*Pi)) mod 2.
- A121262 : The characteristic function of the multiples of four.
- A126565 : a(n) = ceiling(sin(n)*cos(n)).
- A131078 : Periodic sequence (1, 1, 1, 1, 0, 0, 0, 0).
- A131532 : Period 6: repeat [0, 0, 0, 0, 1, 1].
- A131719 : Period 6: repeat [0, 1, 1, 1, 1, 0].
- A131735 : Period 6: repeat [0, 0, 1, 1, 1, 1].
- A133872 : Period 4: repeat [1, 1, 0, 0].
- A141260 : a(n) = 1 if n == {0,1,3,4,5,7,9,11} mod 12, otherwise a(n) = 0.
- A144595 : Christoffel word of slope 4/7.
- A144596 : Christoffel word of slope 2/7.
- A144597 : Christoffel word of slope 3/7.
- A144598 : Christoffel word of slope 5/7.
- A144599 : Christoffel word of slope 6/7.
- A144600 : Christoffel word of slope 2/11.
- A144601 : Christoffel word of slope 3/11.
- A144602 : Christoffel word of slope 4/11.
- A144603 : Christoffel word of slope 5/11.
- A144604 : Christoffel word of slope 6/11.
- A144605 : Christoffel word of slope 7/11.
- A144606 : Christoffel word of slope 8/11.
- A144607 : Christoffel word of slope 9/11.
- A144608 : Christoffel word of slope 10/11.
- A145568 : Characteristic function of numbers relatively prime to 11.
- A152822 : Periodic sequence [1,1,0,1] of length 4.
- A165211 : Period 8: repeat [0,1,0,1,1,0,1,0].
- A166486 : Periodic sequence [0,1,1,1] of length 4.
- A168181 : Characteristic function of numbers that are not multiples of 8.
- A168182 : Characteristic function of numbers that are not multiples of 9.
- A168184 : Characteristic function of numbers that are not multiples of 10.
- A168185 : Characteristic function of numbers that are not multiples of 12.
- A171386 : The characteristic function of 2 and 3: 1 if n is prime such that either n-1 or n+1 is prime, else 0.
- A172051 : Decimal expansion of 1/999999.
- A173857 : Expansion of 3/2 in base phi.
- A179850 : Characteristic function of numbers that are congruent to {0, 1, 3, 4} mod 5.
- A185017 : Characteristic function of 7.
- A187074 : a(n) = 0 if and only if n is of the form 3*k or 4*k + 2, otherwise a(n) = 1.
- A191152 : [4n*e]-2[2n*e], where [ ]=floor.
- A195062 : Period 7: repeat [1, 0, 1, 0, 1, 0, 1].
- A204418 : Periodic sequence 1,0,1,..., arranged in a triangle.
- A232990 : Period 5: repeat [1,0,0,1,0].
- A232991 : Period 6: repeat [1, 0, 0, 0, 1, 0].
- A241979 : (0,1) sequence such that lengths of three consecutive runs are always distinct.
- A267142 : The characteristic function of the multiples of 9.
- A272532 : Single bit representation of the sum of two sinusoids with periods 2 and 2*sqrt(2).
- A283437 : Periodic {1, 1, 1, 1, 0, 1, 0, 0, 1, 0, 1, 1}.
- A320106 : Möbius transform of A320107 a(n) = A001227(A252463(n)).
- A354354 : a(n) = 1 if n is neither a multiple of 2 nor 3, and otherwise 0.
- Beginning: 01010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101010101
- Period: periodic with length 2
- Count: 1001
- Starting seed: 0
- Multiplier: 3
- Increment: 1
- MOD: 2
- Bit value: (x >> 0) & 1
00 { 44-Byte Prgm }
01>LBL "A000035"
02 0
03 STO 00
04 1001
05 STO 01
06>LBL 00
07 RCL 00
08 3
09 ×
10 1
11 +
12 2
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 01111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111
- Period: periodic with length 5
- Count: 65538
- Starting seed: 0
- Multiplier: 2
- Increment: 1
- MOD: 31
00 { 44-Byte Prgm }
01>LBL "A011558"
02 0
03 STO 00
04 65538
05 STO 01
06>LBL 00
07 RCL 00
08 2
09 ×
10 1
11 +
12 31
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 011011011011011011011011011011011011011011011011011011011011011011011011011011011011011011011011011011011
- Period: periodic with length 3
- Count: 105
- Starting seed: 0
- Multiplier: 2
- Increment: 1
- MOD: 7
00 { 44-Byte Prgm }
01>LBL "A011655"
02 0
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 2
09 ×
10 1
11 +
12 7
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001011100101110010111001011100101110010111001011100101110010111001011100101110010111001011100101110010111
- Period: periodic with length 7
- Count: 105
- Starting seed: 12
- Multiplier: 6
- Increment: 5
- MOD: 29
- Bit value: (x >> 2) & 1
00 { 44-Byte Prgm }
01>LBL "A011656"
02 12
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 6
09 ×
10 5
11 +
12 29
13 MOD
14 STO 00
15 4
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 011101110011101110011101110011101110011101110011101110011101110011101110011101110011101110011101110011101
- Period: periodic with length 9
- Count: 105
- Starting seed: 0
- Multiplier: 4
- Increment: 1
- MOD: 73
00 { 44-Byte Prgm }
01>LBL "A060584"
02 0
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 4
09 ×
10 1
11 +
12 73
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001001001101100100100110110010010011011001001001101100100100110110010010011011001001101101100100110110110
- Period: aperiodic
- Count: 105
- Starting seed: 91
- Multiplier: 180
- Increment: 41
- MOD: 179
- Bit value: (x >> 1) & 1
00 { 44-Byte Prgm }
01>LBL "A074937"
02 91
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 180
09 ×
10 41
11 +
12 179
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 10000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010000010
- Period: periodic with length 6
- Count: 65539
- Starting seed: 5
- Multiplier: 4
- Increment: 1
- MOD: 13
- Bit value: (x >> 3) & 1
00 { 44-Byte Prgm }
01>LBL "A079979"
02 5
03 STO 00
04 65539
05 STO 01
06>LBL 00
07 RCL 00
08 4
09 ×
10 1
11 +
12 13
13 MOD
14 STO 00
15 8
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 10000100001000010000100001000010000100001000010000100001000010000100001000010000100001000010000100001000010000100001000010000100001000010000100001000010000100001000010000100001000010000100001000010000
- Count: 16386
- Starting seed: 3
- Multiplier: 6
- Increment: 1
- MOD: 5
00 { 44-Byte Prgm }
01>LBL "A079998"
02 3
03 STO 00
04 16386
05 STO 01
06>LBL 00
07 RCL 00
08 6
09 ×
10 1
11 +
12 5
13 MOD
14 STO 00
15 4
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 010100101101001011010110100101101001010010110100101101011010010110100101001011010010110100101001011010010
- Period: periodic with length 13
- Count: 105
- Starting seed: 83
- Multiplier: 90
- Increment: 5
- MOD: 89
00 { 44-Byte Prgm }
01>LBL "A082848"
02 83
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 90
09 ×
10 5
11 +
12 89
13 MOD
14 STO 00
15 4
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 111000111000111000111000111000111000111000111000111000111000111000111000111000111000111000111000111000111
- Count: 105
- Starting seed: 1
- Multiplier: 3
- Increment: 1
- MOD: 7
00 { 44-Byte Prgm }
01>LBL "A088911"
02 1
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 3
09 ×
10 1
11 +
12 7
13 MOD
14 STO 00
15 4
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 11010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111010111
- Count: 65538
- Starting seed: 2
- Multiplier: 4
- Increment: 2
- MOD: 13
00 { 44-Byte Prgm }
01>LBL "A093719"
02 2
03 STO 00
04 65538
05 STO 01
06>LBL 00
07 RCL 00
08 4
09 ×
10 2
11 +
12 13
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 1100010000000000000000000000000000000100000000000000000000000000000000000000000000000000000000000000
- Period: aperiodic
- Count: 100
- Starting seed: 192
- Multiplier: 157
- Increment: 97
- MOD: 263
- Bit value: (x >> 8) & 1
00 { 44-Byte Prgm }
01>LBL "A094875"
02 192
03 STO 00
04 100
05 STO 01
06>LBL 00
07 RCL 00
08 157
09 ×
10 97
11 +
12 263
13 MOD
14 STO 00
15 256
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 011000011000011000011000011000011000011000011000011000011000011000011000011000011000011000011000011000011
- Count: 105
- Starting seed: 5
- Multiplier: 4
- Increment: 1
- MOD: 13
00 { 44-Byte Prgm }
01>LBL "A095130"
02 5
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 4
09 ×
10 1
11 +
12 13
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 01111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101111101
- Count: 26245
- Starting seed: 0
- Multiplier: 11
- Increment: 5
- MOD: 37
00 { 44-Byte Prgm }
01>LBL "A097325"
02 0
03 STO 00
04 26245
05 STO 01
06>LBL 00
07 RCL 00
08 11
09 ×
10 5
11 +
12 37
13 MOD
14 STO 00
15 4
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 110101111010111101011110101111010111101011110101111010111101011110101111010111101011110101111010111101011
- Count: 105
- Starting seed: 15
- Multiplier: 16
- Increment: 13
- MOD: 29
00 { 44-Byte Prgm }
01>LBL "A098457"
02 15
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 16
09 ×
10 13
11 +
12 29
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000100100100100100100100100100100100100010010010010010010010010010010010010010001001001001001001001001001
- Period: aperiodic
- Count: 105
- Starting seed: 130
- Multiplier: 192
- Increment: 62
- MOD: 191
- Bit value: (x >> 7) & 1
00 { 44-Byte Prgm }
01>LBL "A100283"
02 130
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 192
09 ×
10 62
11 +
12 191
13 MOD
14 STO 00
15 128
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 0001000100001000010001000010000100010000100010000100001000100001000010001000010000100010000100001000
- Period: periodic with length 14
- Count: 100
- Starting seed: 20
- Multiplier: 164
- Increment: 35
- MOD: 163
00 { 44-Byte Prgm }
01>LBL "A105563"
02 20
03 STO 00
04 100
05 STO 01
06>LBL 00
07 RCL 00
08 164
09 ×
10 35
11 +
12 163
13 MOD
14 STO 00
15 128
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 10101000101010001010100010101000101010001010100010101000101010001010100010101000101010001010100010101
- Period: periodic with length 8
- Count: 101
- Starting seed: 0
- Multiplier: 14
- Increment: 3
- MOD: 41
00 { 44-Byte Prgm }
01>LBL "A108357"
02 0
03 STO 00
04 101
05 STO 01
06>LBL 00
07 RCL 00
08 14
09 ×
10 3
11 +
12 41
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 011111101111110111111011111101111110111111011111101111110111111011111101111110111111011111101111110111111
- Count: 105
- Starting seed: 0
- Multiplier: 21
- Increment: 15
- MOD: 43
00 { 44-Byte Prgm }
01>LBL "A109720"
02 0
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 21
09 ×
10 15
11 +
12 43
13 MOD
14 STO 00
15 4
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000000010000001000000100000010000001000000100000010000001000000100000010000001000000100000010000001000000
- Count: 105
- Starting seed: 63
- Multiplier: 150
- Increment: 64
- MOD: 149
00 { 44-Byte Prgm }
01>LBL "A115790"
02 63
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 150
09 ×
10 64
11 +
12 149
13 MOD
14 STO 00
15 128
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 10001000100010001000100010001000100010001000100010001000100010001000100010001000100010001000100010001000100010001000100010001000100010001000100010001000100010001000100010001000100010001000100010001000
- Period: periodic with length 4
- Count: 65538
- Starting seed: 1
- Multiplier: 3
- Increment: 1
- MOD: 5
00 { 44-Byte Prgm }
01>LBL "A121262"
02 1
03 STO 00
04 65538
05 STO 01
06>LBL 00
07 RCL 00
08 3
09 ×
10 1
11 +
12 5
13 MOD
14 STO 00
15 4
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 010010010010011011011011001001001001101101101100100100100110110110110010010010011011011011001001001001101
- Period: aperiodic
- Count: 105
- Starting seed: 113
- Multiplier: 158
- Increment: 43
- MOD: 157
00 { 44-Byte Prgm }
01>LBL "A126565"
02 113
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 158
09 ×
10 43
11 +
12 157
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 111100001111000011110000111100001111000011110000111100001111000011110000111100001111000011110000111100001
- Count: 105
- Starting seed: 7
- Multiplier: 2
- Increment: 1
- MOD: 17
00 { 44-Byte Prgm }
01>LBL "A131078"
02 7
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 2
09 ×
10 1
11 +
12 17
13 MOD
14 STO 00
15 8
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000011000011000011000011000011000011000011000011000011000011000011000011000011000011000011000011000011000
- Count: 105
- Starting seed: 0
- Multiplier: 4
- Increment: 1
- MOD: 13
00 { 44-Byte Prgm }
01>LBL "A131532"
02 0
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 4
09 ×
10 1
11 +
12 13
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 011110011110011110011110011110011110011110011110011110011110011110011110011110011110011110011110011110011110
- Count: 108
- Starting seed: 0
- Multiplier: 8
- Increment: 4
- MOD: 19
00 { 44-Byte Prgm }
01>LBL "A131719"
02 0
03 STO 00
04 108
05 STO 01
06>LBL 00
07 RCL 00
08 8
09 ×
10 4
11 +
12 19
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001111001111001111001111001111001111001111001111001111001111001111001111001111001111001111001111001111001
- Count: 105
- Starting seed: 0
- Multiplier: 8
- Increment: 4
- MOD: 19
00 { 44-Byte Prgm }
01>LBL "A131735"
02 0
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 8
09 ×
10 4
11 +
12 19
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 11001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100110011001100
- Count: 10001
- Starting seed: 1
- Multiplier: 2
- Increment: 1
- MOD: 5
00 { 44-Byte Prgm }
01>LBL "A133872"
02 1
03 STO 00
04 10001
05 STO 01
06>LBL 00
07 RCL 00
08 2
09 ×
10 1
11 +
12 5
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 101110101011101110101011101110101011101110101011101110101011101110101011101110101011101110101011101110101011
- Period: periodic with length 12
- Count: 108
- Starting seed: 46
- Multiplier: 81
- Increment: 29
- MOD: 97
00 { 44-Byte Prgm }
01>LBL "A141260"
02 46
03 STO 00
04 108
05 STO 01
06>LBL 00
07 RCL 00
08 81
09 ×
10 29
11 +
12 97
13 MOD
14 STO 00
15 4
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001001001010010010010100100100101001001001010010010010100100100101001001001010010010010100100100101001001
- Period: periodic with length 11
- Count: 105
- Starting seed: 4
- Multiplier: 12
- Increment: 4
- MOD: 11
00 { 44-Byte Prgm }
01>LBL "A144595"
02 4
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 12
09 ×
10 4
11 +
12 11
13 MOD
14 STO 00
15 4
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000010001000010001000010001000010001000010001000010001000010001000010001000010001000010001000010001000010
- Count: 105
- Starting seed: 14
- Multiplier: 9
- Increment: 6
- MOD: 19
00 { 44-Byte Prgm }
01>LBL "A144596"
02 14
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 9
09 ×
10 6
11 +
12 19
13 MOD
14 STO 00
15 8
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000100100100010010010001001001000100100100010010010001001001000100100100010010010001001001000100100100010
- Period: periodic with length 10
- Count: 105
- Starting seed: 0
- Multiplier: 23
- Increment: 17
- MOD: 41
00 { 44-Byte Prgm }
01>LBL "A144597"
02 0
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 23
09 ×
10 17
11 +
12 41
13 MOD
14 STO 00
15 8
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001010010101001010010101001010010101001010010101001010010101001010010101001010010101001010010101001010010
- Count: 105
- Starting seed: 31
- Multiplier: 29
- Increment: 7
- MOD: 37
00 { 44-Byte Prgm }
01>LBL "A144598"
02 31
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 29
09 ×
10 7
11 +
12 37
13 MOD
14 STO 00
15 4
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001010101010100101010101010010101010101001010101010100101010101010010101010101001010101010100101010101010
- Count: 105
- Starting seed: 11
- Multiplier: 14
- Increment: 1
- MOD: 13
00 { 44-Byte Prgm }
01>LBL "A144599"
02 11
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 14
09 ×
10 1
11 +
12 13
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000000100000100000010000010000001000001000000100000100000010000010000001000001000000100000100000010000010
- Count: 105
- Starting seed: 107
- Multiplier: 14
- Increment: 3
- MOD: 157
- Bit value: (x >> 5) & 1
00 { 44-Byte Prgm }
01>LBL "A144600"
02 107
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 14
09 ×
10 3
11 +
12 157
13 MOD
14 STO 00
15 32
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000010000100010000100001000100001000010001000010000100010000100001000100001000010001000010000100010000100
- Count: 105
- Starting seed: 44
- Multiplier: 23
- Increment: 19
- MOD: 71
00 { 44-Byte Prgm }
01>LBL "A144601"
02 44
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 23
09 ×
10 19
11 +
12 71
13 MOD
14 STO 00
15 8
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000100010001001000100010001001000100010001001000100010001001000100010001001000100010001001000100010001001
- Period: periodic with length 15
- Count: 105
- Starting seed: 77
- Multiplier: 85
- Increment: 2
- MOD: 151
- Bit value: (x >> 6) & 1
00 { 44-Byte Prgm }
01>LBL "A144602"
02 77
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 85
09 ×
10 2
11 +
12 151
13 MOD
14 STO 00
15 64
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000100100100100100010010010010010001001001001001000100100100100100010010010010010001001001001001000100100
- Period: periodic with length 16
- Count: 105
- Starting seed: 40
- Multiplier: 115
- Increment: 37
- MOD: 97
00 { 44-Byte Prgm }
01>LBL "A144603"
02 40
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 115
09 ×
10 37
11 +
12 97
13 MOD
14 STO 00
15 32
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001001001001001010010010010010010100100100100100101001001001001001010010010010010010100100100100100101001
- Period: periodic with length 17
- Count: 105
- Starting seed: 124
- Multiplier: 133
- Increment: 51
- MOD: 137
00 { 44-Byte Prgm }
01>LBL "A144604"
02 124
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 133
09 ×
10 51
11 +
12 137
13 MOD
14 STO 00
15 8
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001001010010100101001001010010100101001001010010100101001001010010100101001001010010100101001001010010100
- Period: periodic with length 18
- Count: 105
- Starting seed: 72
- Multiplier: 158
- Increment: 61
- MOD: 157
00 { 44-Byte Prgm }
01>LBL "A144605"
02 72
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 158
09 ×
10 61
11 +
12 157
13 MOD
14 STO 00
15 64
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001010010101001010100101001010100101010010100101010010101001010010101001010100101001010100101010010100101
- Period: periodic with length 19
- Count: 105
- Starting seed: 8
- Multiplier: 20
- Increment: 8
- MOD: 19
00 { 44-Byte Prgm }
01>LBL "A144606"
02 8
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 20
09 ×
10 8
11 +
12 19
13 MOD
14 STO 00
15 8
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001010101001010101010010101010010101010100101010100101010101001010101001010101010010101010010101010100101
- Period: periodic with length 20
- Count: 105
- Starting seed: 0
- Multiplier: 106
- Increment: 56
- MOD: 241
00 { 44-Byte Prgm }
01>LBL "A144607"
02 0
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 106
09 ×
10 56
11 +
12 241
13 MOD
14 STO 00
15 64
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 001010101010101010101001010101010101010101001010101010101010101001010101010101010101001010101010101010101
- Period: periodic with length 21
- Count: 105
- Starting seed: 152
- Multiplier: 168
- Increment: 8
- MOD: 167
00 { 44-Byte Prgm }
01>LBL "A144608"
02 152
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 168
09 ×
10 8
11 +
12 167
13 MOD
14 STO 00
15 8
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 011111111110111111111101111111111011111111110111111111101111111111011111111110111111111101111111111011111
- Count: 105
- Starting seed: 0
- Multiplier: 58
- Increment: 32
- MOD: 353
00 { 44-Byte Prgm }
01>LBL "A145568"
02 0
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 58
09 ×
10 32
11 +
12 353
13 MOD
14 STO 00
15 32
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 11011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101
- Count: 65538
- Starting seed: 3
- Multiplier: 8
- Increment: 3
- MOD: 13
00 { 44-Byte Prgm }
01>LBL "A152822"
02 3
03 STO 00
04 65538
05 STO 01
06>LBL 00
07 RCL 00
08 8
09 ×
10 3
11 +
12 13
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 01011010010110100101101001011010010110100101101001011010010110100101101001011010010110100101101001011010010110100101101001011010010110100101101001011010010110100101101001011010010110100101101001011010
- Count: 1001
- Starting seed: 0
- Multiplier: 8
- Increment: 7
- MOD: 17
00 { 44-Byte Prgm }
01>LBL "A165211"
02 0
03 STO 00
04 1001
05 STO 01
06>LBL 00
07 RCL 00
08 8
09 ×
10 7
11 +
12 17
13 MOD
14 STO 00
15 8
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 01110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111011101110111
- Count: 65538
- Starting seed: 0
- Multiplier: 8
- Increment: 3
- MOD: 13
00 { 44-Byte Prgm }
01>LBL "A166486"
02 0
03 STO 00
04 65538
05 STO 01
06>LBL 00
07 RCL 00
08 8
09 ×
10 3
11 +
12 13
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 01111111011111110111111101111111011111110111111101111111011111110111111101111111011111110111111101111111011111110111111101111111011111110111111101111111011111110111111101111111011111110111111101111111
- Count: 16385
- Starting seed: 0
- Multiplier: 22
- Increment: 15
- MOD: 73
00 { 44-Byte Prgm }
01>LBL "A168181"
02 0
03 STO 00
04 16385
05 STO 01
06>LBL 00
07 RCL 00
08 22
09 ×
10 15
11 +
12 73
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 01111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101111111101
- Count: 1000
- Starting seed: 0
- Multiplier: 16
- Increment: 6
- MOD: 109
00 { 44-Byte Prgm }
01>LBL "A168182"
02 0
03 STO 00
04 1000
05 STO 01
06>LBL 00
07 RCL 00
08 16
09 ×
10 6
11 +
12 109
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 01111111110111111111011111111101111111110111111111011111111101111111110111111111011111111101111111110111111111011111111101111111110111111111011111111101111111110111111111011111111101111111110111111111
- Count: 1001
- Starting seed: 0
- Multiplier: 46
- Increment: 13
- MOD: 71
00 { 44-Byte Prgm }
01>LBL "A168184"
02 0
03 STO 00
04 1001
05 STO 01
06>LBL 00
07 RCL 00
08 46
09 ×
10 13
11 +
12 71
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 01111111111101111111111101111111111101111111111101111111111101111111111101111111111101111111111101111111111101111111111101111111111101111111111101111111111101111111111101111111111101111111111101111111
- Count: 65538
- Starting seed: 0
- Multiplier: 89
- Increment: 45
- MOD: 229
00 { 44-Byte Prgm }
01>LBL "A168185"
02 0
03 STO 00
04 65538
05 STO 01
06>LBL 00
07 RCL 00
08 89
09 ×
10 45
11 +
12 229
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 011000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
- Period: aperiodic
- Count: 105
- Starting seed: 97
- Multiplier: 2
- Increment: 1
- MOD: 131
00 { 44-Byte Prgm }
01>LBL "A171386"
02 97
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 2
09 ×
10 1
11 +
12 131
13 MOD
14 STO 00
15 128
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000001000001000001000001000001000001000001000001000001000001000001000001000001000001000001000001000001000
- Count: 105
- Starting seed: 8
- Multiplier: 4
- Increment: 1
- MOD: 13
00 { 44-Byte Prgm }
01>LBL "A172051"
02 8
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 4
09 ×
10 1
11 +
12 13
13 MOD
14 STO 00
15 8
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 101001001001001001001001001001001001001001001001001001001001001001001001001001001001001001001001001001001
- Period: aperiodic
- Count: 105
- Starting seed: 77
- Multiplier: 150
- Increment: 50
- MOD: 149
00 { 44-Byte Prgm }
01>LBL "A173857"
02 77
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 150
09 ×
10 50
11 +
12 149
13 MOD
14 STO 00
15 64
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 11011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011110111101111011
- Count: 5000
- Starting seed: 3
- Multiplier: 2
- Increment: 1
- MOD: 31
00 { 44-Byte Prgm }
01>LBL "A179850"
02 3
03 STO 00
04 5000
05 STO 01
06>LBL 00
07 RCL 00
08 2
09 ×
10 1
11 +
12 31
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 000000010000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000000
- Count: 102
- Starting seed: 12
- Multiplier: 8
- Increment: 1
- MOD: 131
00 { 44-Byte Prgm }
01>LBL "A185017"
02 12
03 STO 00
04 102
05 STO 01
06>LBL 00
07 RCL 00
08 8
09 ×
10 1
11 +
12 131
13 MOD
14 STO 00
15 128
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 100110110010100110110010100110110010100110110010100110110010100110110010100110110010100110110010100110110
- Count: 105
- Starting seed: 24
- Multiplier: 7
- Increment: 3
- MOD: 73
00 { 44-Byte Prgm }
01>LBL "A187074"
02 24
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 7
09 ×
10 3
11 +
12 73
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 01010100101010110101010010101011010101001010101101010100101010110101011010101001010101101010100101010110101010010101011010101001010
- Count: 131
- Starting seed: 178
- Multiplier: 182
- Increment: 23
- MOD: 181
00 { 44-Byte Prgm }
01>LBL "A191152"
02 178
03 STO 00
04 131
05 STO 01
06>LBL 00
07 RCL 00
08 182
09 ×
10 23
11 +
12 181
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 101010110101011010101101010110101011010101101010110101011010101101010110101011010101101010110101011010101101010110101011010101
- Count: 126
- Starting seed: 7
- Multiplier: 16
- Increment: 7
- MOD: 29
00 { 44-Byte Prgm }
01>LBL "A195062"
02 7
03 STO 00
04 126
05 STO 01
06>LBL 00
07 RCL 00
08 16
09 ×
10 7
11 +
12 29
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 101101101101101101101101101101101101101101101101101101101101101101101101101101101101101101101101101101101
- Count: 105
- Starting seed: 1
- Multiplier: 2
- Increment: 1
- MOD: 7
00 { 44-Byte Prgm }
01>LBL "A204418"
02 1
03 STO 00
04 105
05 STO 01
06>LBL 00
07 RCL 00
08 2
09 ×
10 1
11 +
12 7
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 10010100101001010010100101001010010100101001010010100101001010010100101001010010100101001010010100101001010
- Count: 107
- Starting seed: 2
- Multiplier: 6
- Increment: 1
- MOD: 5
00 { 44-Byte Prgm }
01>LBL "A232990"
02 2
03 STO 00
04 107
05 STO 01
06>LBL 00
07 RCL 00
08 6
09 ×
10 1
11 +
12 5
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 10001010001010001010001010001010001010001010001010001010001010001010001010001010001010001010001010001010001
- Count: 107
- Starting seed: 5
- Multiplier: 3
- Increment: 1
- MOD: 7
00 { 44-Byte Prgm }
01>LBL "A232991"
02 5
03 STO 00
04 107
05 STO 01
06>LBL 00
07 RCL 00
08 3
09 ×
10 1
11 +
12 7
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 011000100111011000100111011000100111011000100111011000100111011000100111011000100111011000100111011000100111
- Count: 108
- Starting seed: 2
- Multiplier: 2
- Increment: 1
- MOD: 13
00 { 44-Byte Prgm }
01>LBL "A241979"
02 2
03 STO 00
04 108
05 STO 01
06>LBL 00
07 RCL 00
08 2
09 ×
10 1
11 +
12 13
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 10000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010000000010
- Count: 1000
- Starting seed: 8
- Multiplier: 4
- Increment: 3
- MOD: 19
- Bit value: (x >> 4) & 1
00 { 44-Byte Prgm }
01>LBL "A267142"
02 8
03 STO 00
04 1000
05 STO 01
06>LBL 00
07 RCL 00
08 4
09 ×
10 3
11 +
12 19
13 MOD
14 STO 00
15 16
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 101101101001001011011011010010010110110110100100101101101001001001011011010010010010110110100100101101101101001001011011
- Count: 120
- Starting seed: 0
- Multiplier: 182
- Increment: 53
- MOD: 181
00 { 44-Byte Prgm }
01>LBL "A272532"
02 0
03 STO 00
04 120
05 STO 01
06>LBL 00
07 RCL 00
08 182
09 ×
10 53
11 +
12 181
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 111101001011111101001011111101001011111101001011111101001011111101001011111101001011111101001011111101001011
- Count: 108
- Starting seed: 59
- Multiplier: 81
- Increment: 9
- MOD: 97
00 { 44-Byte Prgm }
01>LBL "A283437"
02 59
03 STO 00
04 108
05 STO 01
06>LBL 00
07 RCL 00
08 81
09 ×
10 9
11 +
12 97
13 MOD
14 STO 00
15 1
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 10001110001010001110001010001110001010001110001010001110001010001110001010001110001010001110001010001110001010001110001010001110001010001110001010001110001010001110001010001110001010001110001010001110
- Count: 65537
- Starting seed: 16
- Multiplier: 14
- Increment: 8
- MOD: 37
00 { 44-Byte Prgm }
01>LBL "A320106"
02 16
03 STO 00
04 65537
05 STO 01
06>LBL 00
07 RCL 00
08 14
09 ×
10 8
11 +
12 37
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
- Beginning: 01000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101000101
- Count: 65538
- Starting seed: 6
- Multiplier: 3
- Increment: 1
- MOD: 7
00 { 44-Byte Prgm }
01>LBL "A354354"
02 6
03 STO 00
04 65538
05 STO 01
06>LBL 00
07 RCL 00
08 3
09 ×
10 1
11 +
12 7
13 MOD
14 STO 00
15 2
16 /
17 1
18 AND
19 PRX
20 DSE 01
21 GTO 00
22 .END.
