<-ENG ENG-> 2
01-07-2018, 11:12 PM (This post was last modified: 03-16-2018 12:28 AM by BERNARD MICHAUD.)
<-ENG ENG-> 2
EngSci Update A program that handles Engineering or Scientific adjustment. You can use the result of a calculation on the stack(0.0078), [copy] it to the command line then store it in the variable N, start the program and select option 1 or 2. Variable N will appear in input box #:[0.0078 ] EEX remains '0'.
1 Engineering,
2 Scientific
Press Enter and the info is transferred to the Graphic Screen. From there you press either the top or bottom buttons on the circular Navigation key to increase or decrease the Exponent.
Notice that the Stack number is limited to 11 Digits if you continue pressing up or downthe # will go into Sci notation but the result is still accurate. To Exit press Esc key.
BM
Added note: SI prefix added to EEX
Attached File(s)
.hpprgm  EngSci2.hpprgm (Size: 7.48 KB / Downloads: 4)
