bug in displaying the expression?
05-06-2017, 10:48 AM
Strange bug with physical hp prime:
15/0.015 produces the correct result, but after I press enter, it gets changed to 15/0.02, though I get 1000 (the correct answer). No such problems on emulator on PC or android. Only the physical device is affected. |
05-06-2017, 03:03 PM
RE: bug in displaying the expression?
(05-06-2017 10:48 AM)vkukuruzovic Wrote: Strange bug with physical hp prime: I don't have such problem, what is your Number format ? go to shift-home, and try to change to Standard. primer |
05-06-2017, 03:26 PM
(05-06-2017 03:03 PM)primer Wrote:(05-06-2017 10:48 AM)vkukuruzovic Wrote: Strange bug with physical hp prime: it was not under shift home but shift symbol yes, that was that, changed to standard, and that fixed the problem!! |
