Strange bug with physical hp prime:
15/0.015 produces the correct result, but after I press enter, it gets changed to 15/0.02, though I get 1000 (the correct answer).
No such problems on emulator on PC or android. Only the physical device is affected.
(05-06-2017 10:48 AM)vkukuruzovic Wrote: [ -> ]Strange bug with physical hp prime:
I don't have such problem,
what is your Number format ? go to shift-home, and try to change to Standard.
(05-06-2017 03:03 PM)primer Wrote: [ -> ] (05-06-2017 10:48 AM)vkukuruzovic Wrote: [ -> ]Strange bug with physical hp prime:
it was not under shift home but shift symbol
yes, that was that, changed to standard, and that fixed the problem!!
