Superscript Characters
05-01-2022, 02:58 PM
Is there a consistently sized set of 0 to 9 superscript numbers in the Chars?
I found 0,4,5,6,7,8,9 at 2070 or 8304 in the Chars list and they are all the one size.
Then I found 2 at b2, 3 at b3, and 1 at b9 in the Chars list, these 1 2 and 3 ate the same size as each other, but a different size from the the ones listed above.
I want to use superscript numbers with TEXTOUT_P and also some negative superscript numbers.
Any ideas to get consistently sized ones would be appreciated.
05-01-2022, 04:55 PM (This post was last modified: 05-01-2022 04:56 PM by matalog.)
RE: Superscript Characters
Sorry, I just realised that they display fine when used, they are just displayed a different size in the Chars table.
06-02-2022, 12:24 AM
(05-01-2022 02:58 PM)matalog Wrote:  Is there a consistently sized set of 0 to 9 superscript numbers in the Chars?
Would it be convenient to share screenshots or photos showing this? From looking at Chars palette screens here (in a virtual Prime and on a physical Prime), I’m thinking what you’re seeing might differ from what I see…
Here is what I’m seeing:
(I’ve copied & pasted portions of two screen captures of the Chars palette screen to make the above image. I did that to place all the superscript characters in one row.)
