05-01-2022, 02:58 PM
Is there a consistently sized set of 0 to 9 superscript numbers in the Chars?
I found 0,4,5,6,7,8,9 at 2070 or 8304 in the Chars list and they are all the one size.
Then I found 2 at b2, 3 at b3, and 1 at b9 in the Chars list, these 1 2 and 3 ate the same size as each other, but a different size from the the ones listed above.
I want to use superscript numbers with TEXTOUT_P and also some negative superscript numbers.
Any ideas to get consistently sized ones would be appreciated.
