connectivity kit in background
05-17-2020, 10:49 AM
this morning i ran the hp prime connectivity kit and i updated it with the last revision of january 2020. everything went fine until i rebooted the laptop (triggered by the application). the connectivity kit seems to launch but it remains in background. I can see the connectivity kit active in the app taskbar and there is no way to see the app on the screen… any hint? i run winsows 10 on a hp spectre… thanks Giancarlo |
05-19-2020, 12:39 PM
RE: connectivity kit in background
Probably is just in an offscreen position. In the taskbar, over the ConnKit icon do Shift+Right click and then "move" and then click and drag to the center of the screen
My website: erwin.ried.cl |
05-19-2020, 02:43 PM
Adding to offscreen position.
Activate Kit in the taskbar, press Alt + Space, move with arrows to bring the window to visible area, cancel with Esc if you think you have left it even further away, and accept with Enter to accept. Viga C | TD | FB |
05-24-2020, 01:56 PM
Hello for your hint.
That solved my issue. It is not clear what happened however now it works. Thank you guys for the support. Giancarlo |
