CAS commands in HOME view
04-18-2017, 05:00 PM
(This post was last modified: 04-19-2017 01:25 PM by tdh79.)
Every time I select a CAS command in HOME view I get "Error: Syntax Error" and i have to remove "CAS." from the command i select, is this a common problem or do I have the wrong firmware or something?
04-19-2017, 01:44 AM
RE: CAS cnds in HOME view
(04-18-2017 05:00 PM)tdh79 Wrote: Every time I select a CAS command in HOME view I get "Error: Syntax Error" and i have to remove "CAS." from the command i select, is this a common problem or do I have the wrong firmware or something? Have you tried CAS(yourcommand) rather than CAS.yourcommand? Don't ask me why. The interface between CAS and Home is inconsistent. Tom L Tom L Cui bono? |
04-19-2017, 10:01 AM
(04-19-2017 01:44 AM)toml_12953 Wrote:(04-18-2017 05:00 PM)tdh79 Wrote: Every time I select a CAS command in HOME view I get "Error: Syntax Error" and i have to remove "CAS." from the command i select, is this a common problem or do I have the wrong firmware or something? I can use the function, I just have to remove the "CAS." Ex: When i choose CAS.simplify() i have to remove CAS. so it says simplify() instead. Of course I can just type "simplify" but when i don't know the command i have to locate it in the list and then remove the "CAS." part.. |
04-19-2017, 03:04 PM
RE: CAS commands in HOME view
(04-18-2017 05:00 PM)tdh79 Wrote: Every time I select a CAS command in HOME view I get "Error: Syntax Error" and i have to remove "CAS." from the command i select, is this a common problem or do I have the wrong firmware or something? The latest is the one I would recommend. That is 2016.12.08 r11226 I do not see any behavior you report with that. What do you have? TW Although I work for HP, the views and opinions I post here are my own. |
04-20-2017, 11:22 AM
(04-19-2017 03:04 PM)Tim Wessman Wrote:(04-18-2017 05:00 PM)tdh79 Wrote: Every time I select a CAS command in HOME view I get "Error: Syntax Error" and i have to remove "CAS." from the command i select, is this a common problem or do I have the wrong firmware or something? Properties say: Application version: 20160829 v10637 Operating system version: V0.048.635 Serial number: 3CD62401BX |
04-20-2017, 01:32 PM
(04-19-2017 03:04 PM)Tim Wessman Wrote:(04-18-2017 05:00 PM)tdh79 Wrote: Every time I select a CAS command in HOME view I get "Error: Syntax Error" and i have to remove "CAS." from the command i select, is this a common problem or do I have the wrong firmware or something? On the virtual calc, if you press the toolbox button > CAS > Calculus > diff then the command line shows CAS.diff() Graph 3D | QPI | SolveSys |
04-20-2017, 01:42 PM
(04-20-2017 01:32 PM)Han Wrote:(04-19-2017 03:04 PM)Tim Wessman Wrote: The latest is the one I would recommend. That is 2016.12.08 r11226 Yes, but when i do that on the physical calc I have to remove the CAS. part Apparently the virtual one behaves different from the physical one even though their both set to RPN |
04-20-2017, 03:29 PM
(04-20-2017 01:42 PM)tdh79 Wrote: even though their both set to RPN Well, that information would have been pretty important at the start. Yes, this is the current behavior. No, it probably shouldn't be doing that. TW Although I work for HP, the views and opinions I post here are my own. |
04-20-2017, 03:53 PM
(04-20-2017 01:42 PM)tdh79 Wrote: even though their both set to RPN Well, that information would have been pretty important at the start. Yes, this is the current behavior. No, it probably shouldn't be doing that. I'll file an issue to look at why it is misbehaving in RPN mode here. TW Although I work for HP, the views and opinions I post here are my own. |
04-20-2017, 04:40 PM
(04-20-2017 03:53 PM)Tim Wessman Wrote:(04-20-2017 01:42 PM)tdh79 Wrote: even though their both set to RPN Thanks |
04-24-2017, 07:16 AM
What did you choose as "digit grouping" in the home settings?
Normally you have this problem if in the home settings you are using the , instead of the . as a decimal point i.e. if you select 123456,789 |
04-25-2017, 12:49 PM
(04-24-2017 07:16 AM)retoa Wrote: What did you choose as "digit grouping" in the home settings? Yup, problem gone after i changed it to . as a decimal point. Thanks |
04-25-2017, 03:07 PM
(04-24-2017 07:16 AM)retoa Wrote: What did you choose as "digit grouping" in the home settings? Maybe best solution to avoid this sort of problems is disabling user selectable digit grouping in next firmware release. Prime, 15C CE |
04-26-2017, 06:05 AM
Can you give us example of command line(s) that you are entering in the calculator? Cyrille Although I work for the HP calculator group, the views and opinions I post here are my own. I do not speak for HP. |
04-27-2017, 06:40 AM
(This post was last modified: 04-27-2017 06:41 AM by retoa.)
Hello Cyrille,
if you select 123456,789 as digit grouping every command beginning with CAS.something, like CAS.proot([2 3 -4]) gives a syntax error. If you change it to CAS,proot([2 3 -4]) then it works. To have the "," you have to press "." If you execute the command with 123456.789 as digit grouping and you change it to 123456,789 after the command has been executed on the command line you see CAS,proot([2 3 -4]). Reto |
