Dynamically call a function
06-20-2015, 03:47 PM
hi,
I want call a function dynamically, i.e. nameplanet() to call Mercurius(), Saturnus()... giving a variable: nameplanet (:= "Mercuriius" ...)
This code doesn't work:
  CASE // call constants for planet
  IF nameplanet:="Mercurius" THEN Mercurius(); BREAK; END;
  IF nameplanet:="Venus" THEN Venus();BREAK; END;
  IF nameplanet:="Mars" THEN Mars(); BREAK;END;
  IF nameplanet:="Jupiter" THEN Jupiter(); BREAK; END;
  IF nameplanet:="Saturn" THEN Saturn(); BREAK; END;
  IF nameplanet:="Uranus" THEN Uranus(); BREAK; END;
  IF nameplanet:="Neptunus" THEN Neptunus();BREAK;  END;
  IF nameplanet:="Pluto" THEN Pluto(); BREAK; END;
  DEFAULT data();
  END; // case
It gives "Bad argument type" in my program...
Any hint?
Thanks
Salvo
06-20-2015, 04:06 PM
RE: Dynamically call a function
Try:
IF nameplanet =="Mercurius" THEN Mercurius(); BREAK; END;
not:
and a similar change for the other cases.
Let me know what happens.
Road
06-20-2015, 05:01 PM
(06-20-2015 04:06 PM)roadrunner Wrote:  Try:
hi Road,
you're right!
Today I'm to tired, hi...
Sure, I was assigning a value instead of confront it...
yes, now it's ok!
thank you
Salvo
06-20-2015, 05:43 PM
You can also use (preferentially if nameplanet is not set by the user):
EVAL(EXPR(nameplanet+"()"));
My website: ried.cl
06-20-2015, 05:56 PM
(06-20-2015 05:43 PM)eried Wrote:  You can also use (preferentially if nameplanet is not set by the user):
thank you, I had tried
EVAL(nameplanet())
but it was wrong.
I'll try also this, now!
Salvo
06-21-2015, 07:23 AM
eval() is a powerful capability of dynamic languages, but it bears high speed cost, so it's usually left to non-speed-critical code, as is probably the case here.
Other languages would use an associative array (string, function), or even simply an array in some cases.
06-21-2015, 12:55 PM
(06-21-2015 07:23 AM)debrouxl Wrote:  eval() is a powerful capability of dynamic languages, but it bears high speed cost, so it's usually left to non-speed-critical code, as is probably the case here.
sure, but speed is "no problem" in my case, with ...8 function called and everyone with 20 lines of code...
Here it works well Smile
Salvo
06-21-2015, 03:59 PM
Can you give a coding example of the associative array please.
Cheers,
Hamilton.
06-21-2015, 04:44 PM
(06-21-2015 03:59 PM)hamilton.milligan@outlook.com Wrote:  Can you give a coding example of the associative array please.
Both programs just print 'Uranus'.
Perl
sub Mercurius {
    print "Mercurius\n";
sub Venus {
    print "Venus\n";
sub Mars {
    print "Mars\n";
sub Jupiter {
    print "Jupiter\n";
sub Saturn {
    print "Saturn\n";
sub Uranus {
    print "Uranus\n";
sub Neptunus {
    print "Neptunus\n";
sub Pluto {
    print "Pluto\n";
my %constant = (
    'Mercurius' => \&Mercurius,
    'Venus'     => \&Venus,
    'Mars'      => \&Mars,
    'Jupiter'   => \&Jupiter,
    'Saturn'    => \&Saturn,
    'Uranus'    => \&Uranus,
    'Neptunus'  => \&Neptunus,
    'Pluto'     => \&Pluto,
my $nameplanet = 'Uranus';
$constant{$nameplanet}->();
Python
def Mercurius():
     print 'Mercurius'
def Venus():
     print 'Venus'
def Mars():
     print 'Mars'
def Jupiter():
     print 'Jupiter'
def Saturn():
     print 'Saturn'
def Uranus():
     print 'Uranus'
def Neptunus():
     print 'Neptunus'
def Pluto():
     print 'Pluto'
constant = {
    'Mercurius' : Mercurius,
    'Venus'     : Venus,
    'Mars'      : Mars,
    'Jupiter'   : Jupiter,
    'Saturn'    : Saturn,
    'Uranus'    : Uranus,
    'Neptunus'  : Neptunus,
    'Pluto'     : Pluto,
constant[nameplanet]()
06-21-2015, 08:03 PM
Did you try EXPR() w/o EVAL?:
Nibiru();
EXPORT test()
BEGIN
   nameplanet:="Nibiru";
   EXPR(nameplanet);     // Evaluates EXPRession
end;
Nibiru()                 // Parameter list omitted
begin
  msgbox("Planet X");
end;
06-22-2015, 07:13 AM (This post was last modified: 06-22-2015 07:16 AM by salvomic.)
(06-21-2015 08:03 PM)DrD Wrote:  Did you try EXPR() w/o EVAL?:
ok, yes.
For now the simplest way, in my case, was the Eried tip:
planets()
BEGIN
  LOCAL ch, nameplanet;
  INPUT({{ch,{"Mercurius","Venus","Mars", "Jupiter", "Saturn", "Uranus", "Neptunus", "Pluto"}, {20,30,1}}},
  "Choose planet",
  "planet: ", "Choose the planet to calculate an press OK", 0,5 );
  CASE
  IF ch==1 THEN nameplanet:="Mercurius"; planetCalc(nameplanet); END;
  IF ch==2 THEN nameplanet:="Venus"; planetCalc(nameplanet); END;
  DEFAULT
  END; // case
END;
Mercurius()
BEGUN
END;
it works with a list of planet passing it the name of function to call.
06-22-2015, 08:06 AM (This post was last modified: 06-22-2015 08:12 AM by Didier Lachieze.)
You can also avoid the CASE ... END; with something like this:
planets()
BEGIN
  LOCAL ch, nameplanet:={"Mercurius","Venus","Mars", "Jupiter", "Saturn", "Uranus", "Neptunus", "Pluto"};
  INPUT({{ch, nameplanet, {20,30,1}}},
  "Choose planet",
  IF ch THEN EXPR(nameplanet(ch)+"()"); END;
END;
06-22-2015, 12:43 PM
(06-22-2015 08:06 AM)Didier Lachieze Wrote:  You can also avoid the CASE ... END; with something like this:
planets()
BEGIN
  "Choose planet",
END;
thank you!
I'll try soon...
