hi,
I want call a function dynamically, i.e. nameplanet() to call Mercurius(), Saturnus()... giving a variable: nameplanet (:= "Mercuriius" ...)
This code doesn't work:
CASE // call constants for planet
IF nameplanet:="Mercurius" THEN Mercurius(); BREAK; END;
IF nameplanet:="Venus" THEN Venus();BREAK; END;
IF nameplanet:="Mars" THEN Mars(); BREAK;END;
IF nameplanet:="Jupiter" THEN Jupiter(); BREAK; END;
IF nameplanet:="Saturn" THEN Saturn(); BREAK; END;
IF nameplanet:="Uranus" THEN Uranus(); BREAK; END;
IF nameplanet:="Neptunus" THEN Neptunus();BREAK; END;
IF nameplanet:="Pluto" THEN Pluto(); BREAK; END;
DEFAULT data();
END; // case
It gives "Bad argument type" in my program...
Any hint?
Thanks
Salvo
Try:
IF nameplanet =="Mercurius" THEN Mercurius(); BREAK; END;
not:
and a similar change for the other cases.
Let me know what happens.
Road
(06-20-2015 04:06 PM)roadrunner Wrote: [ -> ]Try:
hi Road,
you're right!
Today I'm to tired, hi...
Sure, I was assigning a value instead of confront it...
yes, now it's ok!
thank you
Salvo
You can also use (preferentially if nameplanet is not set by the user):
EVAL(EXPR(nameplanet+"()"));
eval() is a powerful capability of dynamic languages, but it bears high speed cost, so it's usually left to non-speed-critical code, as is probably the case here.
Other languages would use an associative array (string, function), or even simply an array in some cases.
(06-21-2015 07:23 AM)debrouxl Wrote: [ -> ]eval() is a powerful capability of dynamic languages, but it bears high speed cost, so it's usually left to non-speed-critical code, as is probably the case here.
sure, but speed is "no problem" in my case, with ...8 function called and everyone with 20 lines of code...
Here it works well
Salvo
Can you give a coding example of the associative array please.
(06-21-2015 03:59 PM)hamilton.milligan@outlook.com Wrote: [ -> ]Can you give a coding example of the associative array please.
Both programs just print 'Uranus'.
Perl
sub Mercurius {
print "Mercurius\n";
sub Venus {
print "Venus\n";
sub Mars {
print "Mars\n";
sub Jupiter {
print "Jupiter\n";
sub Saturn {
print "Saturn\n";
sub Uranus {
print "Uranus\n";
sub Neptunus {
print "Neptunus\n";
sub Pluto {
print "Pluto\n";
my %constant = (
'Mercurius' => \&Mercurius,
'Venus' => \&Venus,
'Mars' => \&Mars,
'Jupiter' => \&Jupiter,
'Saturn' => \&Saturn,
'Uranus' => \&Uranus,
'Neptunus' => \&Neptunus,
'Pluto' => \&Pluto,
my $nameplanet = 'Uranus';
$constant{$nameplanet}->();
Python
def Mercurius():
print 'Mercurius'
def Venus():
print 'Venus'
def Mars():
print 'Mars'
def Jupiter():
print 'Jupiter'
def Saturn():
print 'Saturn'
def Uranus():
print 'Uranus'
def Neptunus():
print 'Neptunus'
def Pluto():
print 'Pluto'
constant = {
'Mercurius' : Mercurius,
'Venus' : Venus,
'Mars' : Mars,
'Jupiter' : Jupiter,
'Saturn' : Saturn,
'Uranus' : Uranus,
'Neptunus' : Neptunus,
'Pluto' : Pluto,
constant[nameplanet]()
Did you try EXPR() w/o EVAL?:
Nibiru();
EXPORT test()
nameplanet:="Nibiru";
EXPR(nameplanet); // Evaluates EXPRession
end;
Nibiru() // Parameter list omitted
begin
msgbox("Planet X");
end;
(06-21-2015 08:03 PM)DrD Wrote: [ -> ]Did you try EXPR() w/o EVAL?:
ok, yes.
For now the simplest way, in my case, was the Eried tip:
planets()
LOCAL ch, nameplanet;
INPUT({{ch,{"Mercurius","Venus","Mars", "Jupiter", "Saturn", "Uranus", "Neptunus", "Pluto"}, {20,30,1}}},
"Choose planet",
"planet: ", "Choose the planet to calculate an press OK", 0,5 );
CASE
IF ch==1 THEN nameplanet:="Mercurius"; planetCalc(nameplanet); END;
IF ch==2 THEN nameplanet:="Venus"; planetCalc(nameplanet); END;
DEFAULT
END; // case
Mercurius()
BEGUN
it works with a list of planet passing it the name of function to call.
You can also avoid the
CASE ... END; with something like this:
planets()
LOCAL ch, nameplanet:={"Mercurius","Venus","Mars", "Jupiter", "Saturn", "Uranus", "Neptunus", "Pluto"};
INPUT({{ch, nameplanet, {20,30,1}}},
"Choose planet",
IF ch THEN EXPR(nameplanet(ch)+"()"); END;
