01-20-2018, 05:54 AM
This 50g program expresses any ratio of two integers as an exact decimal number, indicating which digits repeat and which digits do not repeat.
Examples:
Input: 5/12
Output: "0.41_6_" which means 0.416666666... with the 6 repeating forever. The underscores "_" indicate the repeating digit(s).
Input: 13/18
Output: "0.7_2_" which means 0.72222222...
Input: 71/17
Output: "4._1764705882352941_" (all 16 digits repeat forever)
Input: 22/7
Output: "3._142857_"
Input: 15/8
Output: "1.875" (the lack of underscores indicates that the decimal terminates, with no digits repeating forever)
N.B. The longer the repeating section, the longer it takes for the program to run. Example: 115/226 takes 13 seconds to return the answer, which includes a repeating section of 112 digits.
BYTES: 324.5 #3740h
EDIT: A step-by-step analysis of the algorithms used above can be found here: http://www.hpmuseum.org/forum/thread-991...l#pid88913 and an exploration of alternatives for the first 9 lines of code (between FXND and MAX) can be found here: http://www.hpmuseum.org/forum/thread-9955.html
EDIT 2: The variables used in the code above are:
n: Numerator of input
d: Denominator of input
f: length of Fixed (non-repeating) section of digits
r: the saved Remainder
Examples:
Input: 5/12
Input: 13/18
Input: 71/17
Input: 22/7
Input: 15/8
%%HP: T(3)A(R)F(.);
\<< FXND DUP FACTORS DUPDUP @ begin finding length of non-repeating section
IF 2 POS DUP @ how many factors of 2 does the denominator have?
THEN 1. + GET
ELSE NIP
END SWAP DUP
IF 5 POS DUP @ how many factors of 5 does the denominator have?
THEN 1. + GET
ELSE NIP @ MAX(factors of 2 and 5) = number of non-repeating digits
END MAX 0 \-> n d f r @ Numerator, Denominator, Fixed-length (non-repeating), Remainder
\<< n d IDIV2 SWAP "." + SWAP @ put integer part and decimal point into a string
IF f @ Is there any repeating part?
THEN 1. f @ if so, then crank out that many digits of n/d
START 10 * d IDIV2 UNROT + SWAP
NEXT
END @ if not, then fall directly into the repeating-section code
IF DUP @ Are there any repeating digits? (AKA is any remainder left?)
THEN DUP 'r' STO SWAP "_" + SWAP @ if so, the store the initial Remainder, print a "_", and ...
DO 10 * d IDIV2 UNROT + SWAP @ ... crank out digits using infinite division ...
UNTIL DUP r == @ ... until the initial remainder reappears ...
END @ then stop cranking out digits.
END DROP IF r THEN "_" + END @ if there were any repeating digits, print another "_"
BYTES: 324.5 #3740h
