(50g) Integer Ratio to Exact Repeating Decimal
01-20-2018, 05:54 AM (This post was last modified: 01-20-2018 03:20 PM by Joe Horn.)
This 50g program expresses any ratio of two integers as an exact decimal number, indicating which digits repeat and which digits do not repeat.
Examples:
Input: 5/12
Output: "0.41_6_" which means 0.416666666... with the 6 repeating forever. The underscores "_" indicate the repeating digit(s).
Input: 13/18
Output: "0.7_2_" which means 0.72222222...
Input: 71/17
Output: "4._1764705882352941_" (all 16 digits repeat forever)
Input: 22/7
Output: "3._142857_"
Input: 15/8
Output: "1.875" (the lack of underscores indicates that the decimal terminates, with no digits repeating forever)
N.B. The longer the repeating section, the longer it takes for the program to run. Example: 115/226 takes 13 seconds to return the answer, which includes a repeating section of 112 digits.
%%HP: T(3)A(R)F(.);
\<< FXND DUP FACTORS DUPDUP            @ begin finding length of non-repeating section
  IF 2 POS DUP                         @ how many factors of 2 does the denominator have?
  THEN 1. + GET
  ELSE NIP
  END SWAP DUP
  IF 5 POS DUP                         @ how many factors of 5 does the denominator have?
  THEN 1. + GET
  ELSE NIP                             @ MAX(factors of 2 and 5) = number of non-repeating digits
  END MAX 0 \-> n d f r                @ Numerator, Denominator, Fixed-length (non-repeating), Remainder
  \<< n d IDIV2 SWAP "." + SWAP        @ put integer part and decimal point into a string
    IF f                               @ Is there any repeating part?
    THEN 1. f                          @ if so, then crank out that many digits of n/d
      START 10 * d IDIV2 UNROT + SWAP
      NEXT
    END                                @ if not, then fall directly into the repeating-section code
    IF DUP                             @ Are there any repeating digits? (AKA is any remainder left?)
    THEN DUP 'r' STO SWAP "_" + SWAP   @ if so, the store the initial Remainder, print a "_", and ...
      DO 10 * d IDIV2 UNROT + SWAP     @ ... crank out digits using infinite division ...
      UNTIL DUP r ==                   @ ... until the initial remainder reappears ...
      END                              @ then stop cranking out digits.
    END DROP IF r THEN "_" + END       @ if there were any repeating digits, print another "_"
BYTES: 324.5 #3740h
EDIT: A step-by-step analysis of the algorithms used above can be found here: http://www.hpmuseum.org/forum/thread-991...l#pid88913 and an exploration of alternatives for the first 9 lines of code (between FXND and MAX) can be found here: http://www.hpmuseum.org/forum/thread-9955.html
EDIT 2: The variables used in the code above are:
n: Numerator of input
d: Denominator of input
f: length of Fixed (non-repeating) section of digits
r: the saved Remainder
<0|ɸ|0>
-Joe-
01-20-2018, 05:13 PM (This post was last modified: 01-20-2018 09:46 PM by Gerald H.)
RE: (50g) Integer Ratio to Exact Repeating Decimal
Edited to remove DUP1PUTLAM_:
A very nice piece of programming, congratulations.
I've taken the liberty of writing a Sys version, in fact two.
The first uses the function ^Factors to find number of 2's & 5's, the second uses my Sys programme from this thread
which for all fractions I've tested proves faster.
Trust the programmes are of some interest.
CkSum: # C2A3h
  CK1&Dispatch
  BINT10
    FPTR2 ^FXNDext
    DUP
    FPTR2 ^FACTORS
    DUPDUP
    ZINT 2
    SWAP
    FPTR2 ^ListPos
    DUP
    #0<>
    ITE
      #1+
      NTHCOMPDROP
    SWAPDROP
    SWAPDUP
    ZINT 5
    SWAP
    FPTR2 ^ListPos
    DUP
    #0<>
    ITE
      #1+
      NTHCOMPDROP
    SWAPDROP
    COERCE2
    #MAX
    ZINT 0
    NULLLAM
    BINT4
    NDUPN
    DOBIND
    4GETLAM
    3GETLAM
    FPTR2 ^ZDIVext
    SWAP
    FPTR2 ^Z>S
    CHR_.
    >T$
    SWAP
    2GETLAM
    #0=?SKIP
      2GETLAM
      #1+_ONE_DO
      ZINT 10
      FPTR2 ^RMULText
      3GETLAM
      FPTR2 ^ZDIVext
      3UNROLL
      FPTR2 ^Z>S
      &$SWAP
      LOOP
    DUP
    ZINT 0
    EQUALNOT
    IT
      DUP
      1PUTLAM
      SWAP
      "_"
      &$SWAP
      ZINT 10
      FPTR2 ^RMULText
      3GETLAM
      FPTR2 ^ZDIVext
      3UNROLL
      FPTR2 ^Z>S
      &$SWAP
      DUP
      1GETLAM
      EQUAL
      UNTIL
    DROP
    1GETABND
    ZINT 0
    EQUAL
    ?SEMI
    "_"
CkSum: # E5E6h
  CK1&Dispatch
  BINT10
    FPTR2 ^FXNDext
    DUP
    FPTR2 ^ZTrialDiv2
    BINT0
    ROT
    DUP
    ZINT 5
    FPTR2 ^ZDIVext
    ZINT 0
    EQUAL
    WHILE
      SWAPDROP
      SWAP#1+SWAP
    REPEAT
    2DROP
    #MAX
    ZINT 0
    NULLLAM
    BINT4
    NDUPN
    DOBIND
    4GETLAM
    3GETLAM
    FPTR2 ^ZDIVext
    SWAP
    FPTR2 ^Z>S
    CHR_.
    >T$
    SWAP
    2GETLAM
    #0=?SKIP
      2GETLAM
      #1+_ONE_DO
      ZINT 10
      FPTR2 ^RMULText
      3GETLAM
      FPTR2 ^ZDIVext
      3UNROLL
      FPTR2 ^Z>S
      &$SWAP
      LOOP
    DUP
    ZINT 0
    EQUALNOT
    IT
      DUP
      1PUTLAM
      SWAP
      "_"
      &$SWAP
      ZINT 10
      FPTR2 ^RMULText
      3GETLAM
      FPTR2 ^ZDIVext
      3UNROLL
      FPTR2 ^Z>S
      &$SWAP
      DUP
      1GETLAM
      EQUAL
      UNTIL
    DROP
    1GETABND
    ZINT 0
    EQUAL
    ?SEMI
    "_"
01-20-2018, 09:18 PM
"DUP1PUTLAM_" won't compile on a standard HP 50g. Can it be replaced with "DUP 1PUTLAM"?
<0|ɸ|0>
-Joe-
01-20-2018, 09:27 PM (This post was last modified: 01-20-2018 09:38 PM by Gerald H.)
Yes, DUP 1PUTLAM is the correct reading. Sorry, I intended to remove all ?_s. (Now done.)
01-20-2018, 11:05 PM
Thanks, Gerald! Your System RPL programs are much faster than my User RPL program, roughly 16 times faster when the repeating section is large! Good job!
Input: 1/503 (repeating section is 502 digits long)
My program: 60 seconds
Your 1st program: 3.61 seconds!
Your 2nd program: 3.56 seconds!
<0|ɸ|0>
-Joe-
