08-17-2016, 06:28 AM
Within the "Advanced Users Reference" directory on the CD that comes with the 50g, there are 4 files:
CH1.DIR
CH2.DIR
HP 50g AUR.pdf
readme.txt
The readme says the 2 *.DIR files can be transferred to the 50g via SD card, which I confirmed is true. But that readme is deficient in that it doesn't say how to use STO to save that into the 50g's system RAM.
I first copied the 2 files to my SD then put the SD into the 50g. I then used left-arrow & APPS to access FILES, where I can see "SD." I highlight that and press F6 (OK). Then I see the contents. I highlight CH1.DIR and press F4 (RCL), which puts it on the stack.
The data starts off as:
DIR
VOL << 3 ^ π * 4 3 / * ->NUM >>
SPH << ...
If I then type a zero "0" and subsequently push the STO button, I get the following error:
STO Error:
Bad Argument Type
I tried "1" instead of "0" but I get the same error.
The CH1.DIR is rather big at 2k, but I don't think that has anything to do with the error. I must assume there is some way to store it on the calculator, and it's terrible unfortunately that readme.txt file is so lacking in information that it doesn't guide the user to know how to store it, hence this thread.
Any help you can provide would be appreciated. (I'm still new to the 50g, so please be gentle.)
Thank you.
CH1.DIR
CH2.DIR
HP 50g AUR.pdf
readme.txt
DIR
SPH << ...
STO Error:
Bad Argument Type
Thank you.
