General Forum
Pages: 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227
Announcements
Threads
- Hp 50 ; ± What's behind that command/program? (1 Reply)
- ChatGPT for programming (36 Replies)
- [VA] SRC #012f - Then and Now: Angle (15 Replies)
- HP-41CV: Strange "Power Management" (11 Replies)
- HP15c CE: 8x8 equation system (21 Replies)
- [HP48] Kermit setup (9 Replies)
- Proper way to terminate a HPGCC C program after using hpg_set_mode_xxxx()? (4 Replies)
- New HP 15c CE speed tests (18 Replies)
- HP 12C Plus (4 Replies)
- HP41 FOCAL programming: characters on stack? (2 Replies)
- HP 110 "garbage" on screen (29 Replies)
- To merge port memory or not that is the question... (0 Replies)
- Creating GROBS on a computer for HP50G? (2 Replies)
- Capacity of "Topcat" 82033 battery packs (3 Replies)
- oofda! A new HP41 module discovery ?? (12 Replies)
- HP-65/67: Strange AC-Voltage on plug-in supply type 82002A (2 Replies)
- Beginners help (13 Replies)
- 9810 printer temp (0 Replies)
- HP 34C Faceplate (1 Reply)
- HP97 memory problem (7 Replies)
- HP49-HP50 : 'n^a' 'n' 1 5 1 SEQ with no LN? (2 Replies)
- LOTUS 1-2-3 Rel 1A UTILITIES for HP Portable Plus (6 Replies)
- (41C) How to edit & debug complex programs? (18 Replies)
- Is This Economics At Work? (18 Replies)
- Is 50g good or crap? (73 Replies)
- HP41 Battery contacts compatibility between model variants (9 Replies)
- HP48 Insights II usability for 48G (6 Replies)
- RPL integral : 28S vs 48GX (fail to call a program) (5 Replies)
- DIY 41C Feet Replacement - Help (7 Replies)
- HP15C Collectors Edition from Moravia is just born (0 Replies)
