[HP-PIRME] ^ OPERTOR // => SUPER BUG Message #1 Posted by CompSystems on 11 Dec 2013, 12:23 p.m.
google translator =(
M1:=[[1,2,3],[4,5,6]]; // matrix define
M2:=[[1,2,3],[4,5,6],[7,8,9]];
[HOME MODE version ?] numeric math engine
rectangular matrix ^ n => returns a wrong object type must be a string
M1^1; => ~OK Error: Invalid input // => "Error: invalid dimension"
M1^2; => ~OK Error: Invalid input
M1^3; => ~OK Error: Invalid input
M1^4; => ~OK Error: Invalid input
M2^2; = [[30,36,42],[66,81,96],[102,126,150]] // OK
[CAS mode version 1.1.0.27] numeric AND symbolic math engine
M1^1; => "Warning, ^ is ambiguous on non square matrices, Use .^ to apply ^ element by element." ?? => [[1,2,3],[4,5,6]] // == .^ OPERATOR
M1^2; => "Warning, ^ is ambiguous on non square matrices, Use .^ to apply ^ element by element." ?? => 91 // == DOT PRODUCT
M1^3; => "Warning, ^ is ambiguous on non square matrices, Use .^ to apply ^ element by element." ?? =>[[1,8,27],[64,125,216]] // == .^ OPERATOR
M1^4; "Warning, ^ is ambiguous on non square matrices, Use .^ to apply ^ element by element." ?? => 8281// == DOT PRODUCT
SOMETIMES ^ OPERATOR CALCULATED THE DOT PRODUCT, ANOTHER MAKES THE SAME AS THE OPERATOR .^
For this?, is educational? is pedagogical?, if there are specific operators DOTP & .^
Edited: 11 Dec 2013, 1:07 p.m. after one or more responses were posted
