Re: Writing RPL programs on OS X Message #2 Posted by Egan Ford on 27 Nov 2013, 6:25 p.m., in response to message #1 by Sean Freeman
Hi Sean, IIRC there is a 48/50 TTF font floating around for documentation. Whether or not that aligns with the codes in the 50g is unknown to me. However you can probably use it as a base for a custom font. Unicode fonts will probably have all the characters, but then you need to make it ISO-8859-1.
After you figure the fonts out, then the next step is to download and run Ukelele so that you can create a custom keyboard map using the option/alt key for example. This is how I use APL on my Mac. APL has an alien dialect. :-)
After running Ukelele, put your custom keylayout in $HOME/Library/Keyboard Layouts as 50g,keylayout. Then from System PrefLang & Text/Input Sources, select your 50g keylayout. I'd also check "Allow a diff for each document" so that as you jump around apps, they keylayout will remain with your editor/emulator.
Lastly from System Pref/Keyboard/Keyboard Shortcuts/Spotlight, uncheck "show spotlight window". This way you can use the default opt-cmd-space to switch keylayouts quickly.
Oh, instead of a custom font, use unicode chars and define that with Ukelele. Then write a small program to convert your text file from unicode to ISO-8859-1 and vv. I have not found an easy way to make fonts on the Mac based on other fonts, etc...
Good luck.
