Re: PRIMEComm 0.5 Message #7 Posted by Erwin Ried on 23 Nov 2013, 11:53 a.m., in response to message #6 by Harold A Climer
Yeah, the menus are in the 0.6, it included some suggestions and enhancements, but still not published.
I can't understand your second message. This has been tested in only 2 primes for the moment :D so I am not sure what happens with other OS versions (if any), etc. But it is just matter of time.
The chinese chars is because little vs big endian encoding in the files. In this moment:
1) you can receive scripts from your HP to TXT and to hpprgm files (but it is the only version of hpprgm I have implemented, the 'unnamed' one)
2) you can use any hpprgm or txt file as source, but the ones you received first are the most likely to work (it seems there is 1 byte as signature per file, and I am just ignoring all of that and extracting the script, so as I said it is just matter of time/testing/fixing until it works 100% perfect: probably when it reaches 1.0 :D)
The main idea of this little app is to teach in an small article using easy words how to reverse engineer hid/usb stuff you have laying around in the house with old/unsupported/missing features or support, so what you saw working is the only I have discovered up to this moment hahah:
Edited: 23 Nov 2013, 11:57 a.m.
