Re: HP: Dump the predefined variables! Message #4 Posted by Tim Wessman on 19 Nov 2013, 2:12 p.m., in response to message #3 by Chris Pem10
Since apparently I deleted the post rather then edit it, I'll try to remember what it was and post here. This is not directed at the OP.
I doubt this will happen. There are definitely plenty of strong reasons why these are desirable for certain types of users. Simply creating a 50g clone or very similar system will not solve many of the issues which Prime was created to address.
>And dump the Home-View.
I don't think the problem is the concept, but rather the edge interactions. There are plenty of people that have complained about the 49 series having the CAS stick its nose in when not desired. I agree there needs to be additional work here to make things work better for users that don't follow the general workflow now supported.
I suspect a large number of people would just as well get rid of the CAS completely since they never use it and it is a waste of space.
There is a whole wide range of ways to treat variables or content. The 48 series has the design that the user is responsible for managing it completely. If you don't understand it, then too bad. There is a huge number of people that don't want to need to understand the underpinings of a system to use it. Hence the current way things head with phone os systems and computers in general.
The nspire took the route of trying to stick everything into a "document" structure. That has its own sets of issues and makes a lot of problems for power users.
Older high school calcs tried the "don't allow any variables".
I agree that work needs to be done, especially to make Prime work better for the power users that do like to hang out and do things like talk about calculators for fun. Saying though "it should act just like the 50g" though really seems to be rather simplified to the point of ignoring whole other classes of issues.
TW
Edited: 19 Nov 2013, 2:14 p.m.
