Re: Prime: Program size limited to 64K? Message #3 Posted by Erwin Ried on 16 Nov 2013, 5:19 p.m., in response to message #2 by debrouxl
I think it's a display bug:
* in http://www.omnimaga.org/index.php?topic=17406.0 , DJ Omnimaga made a program much larger than 64 KB, before splitting it in pieces larger than 64 KB, due to the unreliability and slowness of transfers with both the HP Connectivity Kit and test_hpcalcs;
* the packet format contains a 32-bit file size field.
Wow that program from DJ Omnimaga is so epic!
You are right, it might be so an artificial limitation, because inside it seems the format can support up to 16MB
http://cl.ly/SVr3
