HP Prime: do not send programs and shuts down by pressing Apps Message #1 Posted by Davi Ribeiro de Oliveira on 12 Nov 2013, 6:47 a.m.
Hello my friends:
As I'm familiarizing myself with this new machine, have accessed quite this Forum, which has given me real quick answers. I have the connectivity Kit installed with version 2013 813 Rev. 5098 that came with the machine.
Well, I can not send programs or any file that has the option to send. There is a newer kit? Other machines have already had this problem? I created a new application with the name Railing in CAS and was creating a new program with the latest guidelines of the friends of the Forum, when, once again, to play the key Apps, the machine turned off. I had to format the machine (I was good at it). Before, I made a backup. Before installing the backup that contains only the application not Railing hangs up on key Apps. If I update with the backup, when touching the key Apps she hangs up.
Get help from friends on these issues?
Thank You
David
