Re: emu48 - copy stack doesn't work (as expected) Message #2 Posted by Gerson W. Barbosa on 11 Nov 2013, 11:31 a.m., in response to message #1 by Thomas Radtke
Stack in Copy/Paste Stack actually stands for the first element of the stack. As far as I know, only real, complex and string objects can be copied. In order to copy a program you should use the ->STR command first. HTH.
Edited: 11 Nov 2013, 11:34 a.m.
