HP Prime - EEX/X/Toolbox-key suggestions Message #1 Posted by bluesun08 on 7 Nov 2013, 5:06 p.m.
In my opinion the toolbox-key and the x-t-Phi-n-key are central keys in HP Prime. They should be nearer on the number field. The EEX-key as a primary key is a dissipation. It is sufficient for shift-key. So my suggestions:
1. Switch the toolbox-key to the EEX-key.
2. Switch the x-t-Phi-n-key to the ON-key, because the ON-key is only used one time in every calculator-usage.
3. The ON-key could switch to the VARS-key, because the VARS-key as a primary key is also a dissipation.
Last but not least: In my opinion, there should be no letters on the operation-keys (+ - * /) so that i can imput longer Variables and operations fluently.
I hope, anybody understand my bad english :-))
