Re: HP Prime - Drawing a circle from a program Message #6 Posted by Jean-Michel on 7 Nov 2013, 3:40 p.m., in response to message #5 by Mic
Mic
in fact, I was using the line() command of the Geometry App in a program, which works fine as soon as you use the following syntax:
line({x1,y1},{x2,y2})
But for an unknown reason, trying to use a similar syntax on the circle() command of the Geometry App in a program does not work. For instance, here is a syntax I tried:
circle({x1,y1},{x2,y2})
I thought this would draw a circle where x1,y1 and x2,y2 would be the coordinates of two end points of a diameter.
Kind regards.
