There are some things the HP 50g does better than the HP Prime Message #1 Posted by Michael de Estrada on 4 Nov 2013, 9:41 a.m.
Although there are definitely improvements in the way HP Prime handles complex problems, the old HP 50g still has the edge when it comes to more simple situations. For example, let's say I want to convert a 25 m^2 area into a result in ft^2. On my HP 50g the keystrokes would be as follows:
25 <right shift> UNITS AREA m^2 <left shift> ft^2
And voila, the result 269.0978_ft^2 is immediately displayed. Note that everything was done on the command line w/o the need to use the Enter key. Now let's see how I would handle the same problem on the HP Prime:
<Shift> Units Tools CONVERT 25 <Shift> Units Units Area m^2 ,1 <Shift> Units Area ft^2 Enter
which is a lot more involved with many more keystrokes. One problem with the menu system in the Prime is that after a single selection you are returned to the main Home or CAS screen, and have to re-enter and navigate the menu repeatedly to select more entries. With the 50g once you are in a particular submenu of a particular feature you remain there until you select another feature.
Edited: 4 Nov 2013, 10:42 a.m.
