Re: PRIME Lockup after pressing Enter key in Solver. Message #12 Posted by Harold A Climer on 14 Oct 2013, 5:14 p.m., in response to message #11 by Michael de Estrada
OK, the mystery is solved.
There are two versions of the Users Guide:
Version dated May 2013 - Located in Emulator install directory of computer hard drive. Contains an Appendix B - Troubleshooting that begins on page 531, and discusses various key sequences to achieve a reset or restore of default settings. No mention of reset button on back of calculator.
Version dated July 2013 - Downloaded from online links. Contains an Appendix B - Troubleshooting that begins on page 591 and contains only a description of how to reset the calculator via the reset button on the back of the calculator.
Here is the text
Troubleshooting
Calculator not responding
If the calculator does not respond, you should first try to
reset it. This is much like restarting a PC. It cancels certain
operations, restores certain conditions, and clears
temporary memory locations. However, it does not clear
stored data (variables, apps, programs, etc.).
To reset
Press and hold On and SYMB keys simultaneously, and then
release them.
If this doesn’t work, you should restore factory settings (see
below).
To restore factory settings
If the calculator does not respond to a reset (see above),
you should restore factory settings. This will entirely erase
the calculator’s memory. You will lose everything you have
stored.
1. Press and hold ON then APPS and then ESC.
2. Release all keys in the reverse order.
If the calculator does not turn on
If the HP Prime does not turn on, follow the steps below
until the calculator turns on. You may find that the
calculator turns on before you have completed the
procedure. If the calculator still does not turn on, contact
Customer Support for further information.
1. Press and hold ON for 10 seconds, then release.
NOTE This is where the second key to press is not obvious
Have no idea as to what key "?" is.
2. Press and hold On and ?simultaneously ?, then
release?, then release On.
3. Press and hold On,?,and? simultaneously. Release ?, then release ?, and then release On.
4. Remove the batteries, press and hold On for 10
seconds, then put the batteries back in and press On.
