Re: HP Prime spreadsheet Message #8 Posted by cyrille de Brébisson on 9 Oct 2013, 1:43 a.m., in response to message #7 by Joseph Ec
Do you mean that you want to get a A1:C3 for example as an input and you want to deconstruct it as R1=1 C1=1 R2=3 C2=3 ?
I am sorry that there is no build in facility to do so. The only solution that I Can think of would be by transfroming to string and analyzing the string...
If you want to see what is stored in a Row/Colomn header then you can use Cell(0,Col,n) or Cell(Row,0,n) to get access to it (formulas, and all meta data).
depending on n, you get access to different data:
-1: all attributes. If the cell has nothing defined, returns -1, else return a list of 11 objects.
0: value (read only, you can not set the cell value)
1: formula
2: name
3: number format: Standard = 0, Fixed = 1, Scientific = 2, Engineering = 3, unspecified = –1
4: number of decimal places: 1 to 11, or unspecified = –1
5: font: -1: 0 to 6, unspecified = –1
6: background color: cell fill color (color, or 32786 if unspecified)
7: foreground color: contents color (color, or 32786 if unspecified)
8: horizontal alignment: Left = 0, Center = 1, Right = 2 , unspecified = –1
9: vertical alignment: Top = 0, Center = 1, Bottom = 2, unspecified = –1
10: show strings in quotes: Yes = 0, No = 1, unspecified = –1
11: textbook mode (as opposed to algebraic mode): Yes = 0, No = 1, unspecified = –1
Cyrille
