HP Prime Cellular Automaton Message #1 Posted by CompSystems on 4 Sept 2013, 8:56 a.m.
more info
http://calc.fjk.ch/?p=826
Video:
http://www.youtube.com/watch?feature=player_embedded&v=imWvQHUjt2I
CADraw(Pop,Y,Color)
LOCAL I;
FOR I FROM 1 TO 320 DO
PIXON_P(I-1,Y,Color(Pop(I)+1));
CARun(Rule,Pop)
LOCAL Color,Sum,I,J,A,B,C;
Color:={RGB(0,0,0),RGB(255,0,0),RGB(0,255,0),RGB(0,0,255)};
RECT();
CADraw(Pop,0,Color);
FOR J FROM 1 TO 239 DO
A:=Pop(320);
B:=Pop(1);
C:=Pop(2);
// offset sum to avoid addition at rule access
Sum:=A+B+C+1;
Pop(1):=Rule(Sum);
FOR I FROM 2 TO 319 DO
Sum:=Sum-A;
A:=B; B:=C; C:=Pop(I+1);
Sum:=Sum+C;
Pop(I):=Rule(Sum);
Sum:=Sum-A+Pop(1);
Pop(320):=Rule(Sum);
CADraw(Pop,J,Color);
FREEZE;
EXPORT CA2D(Rule,Pop)
IF SIZE(Rule)#10 THEN
MSGBOX("Rule must be list of size 10 ");
ELSE
IF SIZE(Pop)#320 THEN
MSGBOX("Pop must be list of size 320");
ELSE
CARun(Rule,Pop);
EXPORT Rule1()
RETURN {0,1,2,0,1,3,3,2,3,0};
EXPORT Rule2()
RETURN {0,1,2,0,3,0,2,2,3,0};
// there are many more interesting rules
Pop1X(V)
LOCAL Pop;
Pop:=MAKELIST(0,K,1,320,1);
Pop(160):=V;
RETURN Pop;
EXPORT PopR()
RETURN MAKELIST(RANDINT(0,3),K,1,320,1);
EXPORT Pop1()
RETURN Pop1X(1);
EXPORT Pop2()
RETURN Pop1X(2);
EXPORT Pop3()
RETURN Pop1X(3);
In Basic
Request for HP
0: On the catalog of programs, if a program contains n subroutines visible (export) allow explore with right cursor key
1: allow certain properties as read only etc
2; command to make a scroll over the image and accessed from HOME or CAS (~ PICTURE hp48/50)
Edited: 4 Sept 2013, 10:39 a.m.
