Re: Matrix Message #3 Posted by Thomas Klemm on 18 Aug 2013, 6:17 p.m., in response to message #1 by Richard Berler
Without reading the aforementioned manual: a matrix descriptor consistst of three numbers: the register i where to start storing the elements, the number of rows r and the number of columns c. These three numbers are merged into one using the format i.rrcc. So for instance 5.0203 is a matrix descriptor for a 2x3 matrix whose elements are stored in register 05 and the following. This is similar to the numbers we use for ISG and DSE.
The simplest way to enter a matrix is using the program MED. Use up- and down-arrows to navigate through the elements. But you can just as well store the numbers in the correct registers.
Say you want to find the inverse of [[1 2][3 4]]:
1 STO 00
2 STO 01
3 STO 02
4 STO 03
0.0202 M-1
RCL 00 -> -2
RCL 01 -> 1
RCL 02 -> 1.5
RCL 03 -> -0.5
Compared to the HP-15C you have to make sure the matrix descriptors don't specify overlapping regions. But you are not restricted to use just five matrix descriptors.
Kind regards
