hp 39gii lcd clear question Message #1 Posted by giancarlo on 17 Aug 2013, 11:29 a.m.
I know that you are all playing with the Prime. As usual I am a step behind and still playing with my (real) hp39gii.
I wrote a simple program that creates, for each loop iteration, a number and display it via the 'print' command. When the program ends the stack is empty.
If i run the same program twice, i can still see the results of the first run of the program and the new ones. It seems it is a kind of stack which is different from the one available for calculation which is not cleared at each program run and cannot be cleared via the 'rect()' command like a grob.
If i switch off the calc, this stack is empty like a kind of garbage collection.
Any idea of the command i can use to clear the stack?
It is possible i didn't install last firmware so please apologize for not being up to date.
Thanks
Giancarlo from Italy (training for the prime)
