[HP Prime CAS] Request: TRUE & FALSE Message #1 Posted by CompSystems on 3 Aug 2013, 10:29 a.m.
Sorry google translator
The HP-Prime have 2 new constants, true and false =)
you can try
EVAL(true) => 1
EVAL(false) => 0
Request 0: Evaluate first to TRUE or FALSE all CAS commands than return 1/0, including comparisons ==, >, < etc, Return TRUE or FALSE is more didactic
Example1:
type(3+4*i) == DOM_COMPLEX [Enter] 1 // Current
type(3+4*i) == DOM_COMPLEX [Enter] TRUE // best
eval(ans) => 1
Example2:
x+4=6 | x=2 [Enter] return 6=6
EVAL(x+4=6 | x=2) [Enter] 1 // Current
EVAL(x+4=6 | x=2) [Enter] TRUE // best
Example3:
x+4=6 | x=2.0001 [Enter] return 6.0001=6
EVAL(x+4=6 | x=2.0001) [Enter] FALSE
5 > 4 => true
The following program evaluates the accuracy of the answer given by the SOLVE command
errors, why?
prg version 0.2
Export Prg1
Begin
Local eq, eq1, eq2, eq3, var, var1, var2 sol, sol1, sol2, test1, test2;
eq1 := x+4=6; // x = 2
eq2 := 2^(2*x+1) = -1+ 32*2^x; // x = -4.99... OR x = 3.99...
eq3 := x^4=4; // x = v¬2 or x -v¬2
eq4 := { 4*x+3*y=10, 5*x-2*y=1 } // x = 1 AND x = 2
eq : eq1
var1 := x;
var2 : y;
var : var1
//purge( rcl(var1), rcl(var2) ); => purge ( x, y ) ?
sol := solve( eq, var ); // for eq1/2/3
//sol := solve( eq, {var1, var2} ); // for eq4
sol1:= ( var = sol(1) ) // for eq1...4
//sol2:= ( var = sol(2) ) // only for eq2, eq3, eq4
// sol12:= ( { var1, var2 } = sol ); // for eq2/3/4: [ sol ] => [ vars = sol ]
test1 := ( eq | sol1 );
//test2 := ( eq | sol2 );
If ( EVAL(test1) == true ) // Accuracy Solve Command
Then
msgBox( "case true => " + sol1 + " " + test1 );
Else
msgBox( "case false => " + sol1 + " " + test1 );
EndIf;
Then
msgBox( "case true => " + sol2 + " " + test2 );
Else
msgBox( "case false => " + sol2 + " " + test2 );
EndIf;
End;
Edited: 4 Aug 2013, 11:02 a.m. after one or more responses were posted
